ENERGY AMPLIFICATION
0 Members and 100 Guests are viewing this topic.
Magluvin
Quote from: PARAV on August 24, 2012, 09:26:38 PM
Hi MaGs,
Thanx for being there with your suggestions on  Dave 45's ideas---Can you show us a rough schematic of what you think, of how this could be wired up----Thanx again--Paul
Hey Parav
Well we seem to have a bunch of things to try. Utkin pdf below and Daves idea. They all include 2 oppositely wound coils, inline on a straight core, or possibly toroidal like Dave suggests.
Im winding my first tonight to try a few things before I commit to a certain design. ;]
MaGs
PARAV
Quote from: Magluvin on August 24, 2012, 09:29:15 PM
Ill figure out something to work for you. What freq range do you want to work with? Input voltage? And what is your idea for a primary coil, as in no. of turns, wire size?
It would be good to have some base lines so when I design the circuit, we are in the area you want to be, the first time. ;]
MaGs
Hi MaGs,
Thanx for the quick response--
I'm just kind of on the side lines with this at the moment as I , too, am waiting for some of Dave's inputs to figure out some  of the  circuitry---eg, -a  high voltage oscillator input  --then incorporate it with a type of flipflop multivibrator  of sorts .
I think he/(we) need a alot of help from guys like you to get some ideas down on to a circuit diagram--- Paul
Magluvin
No problem Parav.  I suggest you read the pdf. It talks about a lot of what we are looking to do. Dave has more of a trifi happening. I dont know if that is necessary, but every which way we try, hopefully gets us to our destination. ;] And eliminates non working posibilities.
I have been thinking about these setups for a while. I just couldnt grasp the electrical field end of it all. Im starting to get it. Just thinking on my own, having the electrical fields flowing in opposing directions, I wonder if there is some kind of twisting between the 2 coils, like a spring. ;]  or you hear the term 'vortex' thrown around. So 2+2 is 4  ;]
I dunno.  So im going to try a few things. If there is any effects, more than likely there should be some evidence of it with single input pulses and tests. At least I want to try things like this first. Maybe use light bulbs in series with windings at first, so if things get out of hand, the bulb will light and increase resistance in the circuit to regulate things a bit. If there is a buildup upon starting, it should be able to be measured before the bulb heats up, if it does, depending on the bulb, and depending on what ever. Im thinking of other safety mechanisms for the just in case moments. Who knows. Teets says to get the long rubber gloves. lol  I have to say, no harm there. Get some gloves. ;]
This kind of winding and configurations are not in books at the library. If you get into this project, take some extra precautions. Nobody needs to get hurt or worse. ;]
MaGs
Dave45
Hey Mags
Iv been thinking the same thing, Im going to start winding tomorrow, I may go the high voltage route just because I have the parts and the schematic is simple, but I'll be nowhere near it while its running  ;D Im chicken  ::)
I think because of the shorted coils and the poles having the same orientation the system will become one. speaking of the electric fields there are some vids I would like you guys to see, I have obligations for awhile today but will look them up and post them here this evening.
Dave45
Here's one Min2oly is using a sniffer coil hooked to his scope it shows the polarity of the electric fields outside the coil.http://www.youtube.com/watch?v=_xq9VVGYoSU&feature=uploademail
notice his coil is in a vertical position this is important for a clean signal
