ENERGY AMPLIFICATION
0 Members and 231 Guests are viewing this topic.
Magluvin
Hey Dave
Im still not getting it. In your last animation, are we looking at a single coil with a HV pulse sent through its leads?  And if so, Are you saying that if we put a pickup coil on one end of the pulsed coil, that the voltage/current will be different than if the pickup coil were on the opposite end of the pulsed coil?
If so, it seems odd that this info isnt more well known.
Will be doing tests tonight with my coil. Got to go to my shop for a few hours. Labor day labor. ;]
Mags
Dave45
QuoteThe reason for this strange behavior is the inductor. When current first starts flowing in the coil, the coil wants to build up amagnetic field. While the field is building, the coil inhibits the flow of current. Once the field is built, current can flow normally through the wire. When the switch gets opened, the magnetic field around the coil keeps current flowing in the coil until the field collapses. This current keeps the bulb lit for a period of time even though the switch is open. In other words, an inductor can store energy in its magnetic field, and an inductor tends to resist any change in the amount of current flowing through it.
http://electronics.howstuffworks.com/inductor1.htm
Back electromotive force is a voltage that occurs in electric motors where there is relative motion between the armature of the motor and the external magnetic field
Its very well known, just not understood, its a product of the magnetic field.
dave
Dave45
Most switching power supply's and transformers use ac and using ac this action is not recognizable
http://makeagif.com/f4lh9N
Notice in both secondary's we get voltage and amperage, how would it be recognizable.
But with a direct current source it is recognizable as femf and bemf.
Dave45
It would seem a strong enough magnetic field could tear space itself, maybe this is why they call the core of a galaxy a black hole.
If we think on how a pulsed coil works pulling in two directions from the center out, we can see how it creates a low pressure zone in the aether, they say the aether has a potential so creating a low pressure zone would draw in energy.
