ENERGY AMPLIFICATION
0 Members and 73 Guests are viewing this topic.
totoalas
Quote from: DilJalaay on January 25, 2014, 10:54:05 AM
Hello Tito Sir,
Are you going to delete your posts or not, as i am reading your old posts, and i am v v very much close to your secrets, then i will tongue you :P  (just joking sir). You are my much favorite teacher sir, i love your way of teaching, and much respecting you.
My questions, are you still using battery as a source for your device?
2nd can we make an other kick on a kick? double kick on single input?
Is your 1st schematic is still valid or workable or you have an other better method? (attached)
Regards,
D.J
:) ;) :D ;D >:( :( :o 8) ??? ::) :P :-[ :-X :-\ :-* :'(
DilJalaay
 :D ;D ;)
Setup#01 and 2, are Averminko plugs, almost no power using to charge the caps and good bang.
Setup#04 is very power full bang.
Turn off the power supply still you can do some more bangs.
setup#05 not checked yet.
MOST IMPORTANT:  Also take care to look, i am not killing the dipole.
DilJalaay
Quote from: totoalas on February 02, 2014, 11:20:46 AM
the set up   12 v battery   in parallel  to the cap    the cap in the center or source  the other end in series with 24 v batteries  thru the vibrator or tuning fork as he described it in the 4 pole contact relay used in planes
in Titos circuit   he replaced the 12 v  with a 24v primary/ 220 v secondary   transformer.... using ordinary relay
cap diode to protect the contacts   and the relay itself  using the negative or one side of coil  connected to the nc contact    the other end of coil connected to other side of relay coil......    or just the no contact to a computer fan using reed switch or metal contacts to charge discharge  kick  and kick back
what can you say  Otits   based on ur first sketch mentioned last week
:( not get what you are saying.
A schematic/drawing will be very much appreciated.
Thanks..
that-prophet
Quote from: that_prophet on December 06, 2013, 12:25:06 AM
GEM=God's Electricity Machine
Free energy is so simple,
That we have missed it.
In our looking for such complex ways to fight friction costs.
We have failed to look at simple geometry
How you can multiply your rotations with changing the size of pulleys
Please remember, with electricity, more rotations is more power
Free energy has been discovered = (this is a Gift from God)
- By a Born-Again pre-Trib Saint  (pre-Trib began early 2012),
-   Scriptural Proof we are allowed to know these doors/deadlines (Mat 24:33)
I call this free energy machine a GEM = (God s Electricity Multiplier)
This one_christian_warrior was shown this Miracle by the God of our Holy Bible
-   from The God of the Bible = (Father +Jesus +Holy Spirit)
I believe this might be because I asked our Father for something to help others,
-   + not for myself = ( though it does bring me great joy )
I have always wondered about how I could help my future Tribulation Saints
-   So I asked for some way to help these Tribulation Saints be better
-   -   Able to survive easier, so they can make it past the Great Tribulation
- When they would have to survive our Canadian winters
-   -   off the power grid
He first showed me a Vision, of a ten-speed bicycle going up + down a hill
-   Where if you drove up the hill in tenth gear, (few turns of the pedals)
-   -   Then back down in first gear
-   -   -   You would do far less pedaling up the hill
-   -   -   -   Then pedal like crazy all of the way down
-   -   With electricity, more rotations equals more AC electricity (power)
Then, as a confirmation, that this came from Good Forces = Holy Spirit
-   + not bad ones (fallen angels)
-   -   I found it described in Ezekiel 1:16,
-   -   -   Where they were trying to describe the workings of a UFO:
-   -   -   -   Or chariot of fire (2Kings 2:11)
When you take a careful look at this technology
-   It seems obvious (the more generators you add, the greater the multiplication factor)
-   -   You put power into a motor with a large pulley
-   -   -   Which you only have to turn the one single turn (very little energy)
Then you take power out of the one to a hundred small pulleys with generators
-   That you attach to the same belt
-   -   Each generator rotates tens to hundreds of times faster
-   -   -   Each rotation gives you electricity (lots of energy)
-   -   -   -   It is truly that simple
I believe that it can't help but work
-   Then why has this simple method of gaining free energy been hidden for so long
-   -   It is because Satan + his evil spirits are working hard hiding this
-   -   -   How else do you explain this not being discovered earlier
-   -   -   -   Like, as soon as electricity had been discovered
-   -   -   -   -   This is soooooooooo simple
-   -   -   -   -   -   Why has it been hidden
Well, it is hidden no longer. I have published for all to use freely
- at : http://free-energy.yolasite.com/
+ what I heard on the web
-   -   that if a person publishes something on the web
-   -   -   and chooses not to patent it, like I have done
-   -   -   -   then it opens it up for all to use freely
-   -   -   -   -   without having to pay any patent fees
I have this, and two other unique ideas given me by God that I have published
-   On the web at this website http://beliefstoliveby.yolasite.com/
You use pulleys to multiply your rotations
And with electricity, more rotations is equal to more electricity
The massive multiplication of rotations is where we can gain the energy. The idea is to put power into the torque of rotating the large pulley of the DC drive motor, which is converted into massive amounts of rotations of the output generators, as we can connect tens if not hundreds of output generators through simply increasing the size of the belt that drives them to accommodate the increase in the number of small pulleys. The vast amount of multiplications of rotations gives you enough power to not only power itself, but cover any loss due to friction, and actually generate an excess of energy. The idea is, to use simple geometry(size change of diameters) to create an increase of rotations through massive circumferential differences. In effect, you are multiplying the power.
We don't need the air polluting effects of the combustion engine any more
We have self-generating electricity generators
That can be made to practically any size or voltage
So that we have the choice to have almost everything self powered
I know this will work, and I believe that this will change the world that we live in for the better. I proved that the idea works with my electric wheelchair experiment, but I have not been able to get a bicycle light generator to finish the prototype.(something I will be struggling to remedy for a while now) I also thought of using an electronics simulation software to not only prove that it works, but then we would have a video of how one actually works. I know, it`s so simple it seems too simple to work, and if it would work, then why wouldn't someone have thought it up earlier.
I know, it`s so simple it seems too stupid to work, and if it would work, then why wouldn't someone have thought it up earlier.
I figure that if you keep adding output generators to the belt
then you would eventually generate enough power
to make up for the power that you are putting into the drive motor
as well as any losses due to friction
until you add enough output generators
to have not only have a self powered machine
but you can get an excess of power as an output
= free energy output generator
Here are a few of the reasons for this system to work miracles
- The massive circumferential differences between a large drive rotor
o You put power into turning a motor only once-(lg)
§ When the power out generator(s) spin hundreds of times faster
· Each rotation gives you power to put back into the system
- Then you could add tens of these output generators
o All of these would be turning the many hundreds of times faster
- Them you could enlarge the drive motor pulley to the max
o As well as shrinking the size of the pulleys on the output generators
§ to make the multiplication factor even more
- So lets see, you are putting energy into the high torque motor with a large pulley
o And then through extreme size differences in pulleys
§ As well as the simple addition on 10`s if not 100`s of generators
· You get your many generators to spin many rotations
o That you are getting power out of
§ While your input motor only turns the once
· You have to make power
You need one DC motor as an input motor
Then you need at least one AC motor as a generator
This is one of the easiest way to multiply your input power
By adding additional output generators
on the same belt as your input DC motor with the one large pulley
Or, you could change size of the pulleys is another way to effect your multiplication
by shrinking diameter of output generator(s) pulley
or increasing diameter of DC input motor pulley
are other ways of increasing you multiplication
the drive motor and all of the generators could be any voltage
as long as they are of the same voltage
you might need to use voltage regulators
to keep this contraption running smoothly
Maybe this mechanism should be called an electricity multiplier
As you always need the initial amount of electrical power
To be multiplied into your gaining of free energy
Which can be initialized by giving the large pulley a turn by hand
this is a Miracle from God
yes, it does indeed work
using size change in diameters of pulleys
to multiply the rotations of your input motor
by the large change in circumferences of the pulleys
as in, the multiplication factor is due to
the tens if not hundreds of times the circumference changes
I just don't like the idea of somebody blowing up a battery
And maybe even catching fire
Now, most likely you will not be interested in this Spiritual part
But I discovered this by praying and asking the God of the Holy Bible
for a way to help us earthlings, the Tribulation Saints mostly
Especially during the 3.5 years of the Great Tribulation
Where they will need a way to survive our cold Canadian winters off the electricity grid
Don't believe in Satan or evil forces
Please explain why this simple idea
Of using change in size of pulleys to multiply electrical power
Has not been discovered all ready
to all Who are in the Family of Christ
this is for the tribulation saints
how else do they stay alive + hidden
in our cold Canadian winters
WARNING = the pre-Trib started on March 14th, 2012
http://doorschristmustpassthrough.yolasite.com/
joe lynch
one_christian_warrior@yahoo.ca
Diagrams of some uses for this technology are at:
