ENERGY AMPLIFICATION
0 Members and 63 Guests are viewing this topic.
totoalas
Quote from: Magluvin on February 06, 2014, 07:46:06 PM
Im not sure that Tesla used condensers as diodes. But Cadman is correct in certain uses.
Ive read where the cap was used to allow a certain amount of current to pass(series pass), just in case there is a short or similar issue later in the circuit. It was a way of limiting full current from the source in case of problems.
Large inductors, I see them like an isolation device for spikes or pulses to keep them in the circuit not allowing them back out to the source. But if the large inductor is kept spinning(flywheel), it would be hard to have a current reversal during continuous operation.
But I believe Tesla used timed switching for rectification more than anything. My Lasersaber EZ motor build, the rotor can be spun either direction and charge a cap + or - depending on the rotor direction. So the reed switching only allows one polarity out from the motor. Same as when it runs from a source, dc is only applied to the coils at the right time.
Toto, your build of Gyula's circuit, was it self sustaining or more out than in? The reason I said what I said was, I thought thst you did build that circuit, but you just said also you want to build Tito's circuit. Well wasnt that circuit Titos circuit?  ??? ;D
Mags
Gyuylas circuit is great but moneywise ive spent a lot zero watts in  40 watts out
for titos circuit first   one
he used eric dollard   instead of 12 v battery he replaced it with 24 v 220 v  step up xfmr   a cpu fan for switching
a cap diode relay and an inverter   which I know you have all in hand or in stock
let us start from here and later  migrate to a more so
lid ttechno stuff   :) ;)
a.king21
Mags
Do you have a schematic of Gyuala's circuit?
Magluvin
Neo-X
Not again, sawa na ako dito  :(
Marsing
hi..
will someone post a complete diagram instead of a confusing part?
maybe never
lol.
