ENERGY AMPLIFICATION
0 Members and 44 Guests are viewing this topic.
Bruce_TPU
Quote from: totoalas on February 10, 2014, 10:23:01 PM
Hi Totoales,
i have MUCH respect for you and Grum and other REAL experimenters.
But please ignore open voltage.  Not saying it doesn't mean anything,  just saying you'll only know measuring across a resistor and using rms voltage on scope.  Or smooth to dc then resistor.
I am interested in the use of ground.  But again, measure across a resistor without ground, etc and the with and see if there is a difference.  If so, then you may be onto something.
Good job,
Bruce
Magluvin
Above all, the fact that the out V is greater than the in V is the interesting part. it does seem to be a 1to1 ratio. And it is simple AC in AC out.  Now if it were pulsed or square in, then I wouldnt be so surprised. Makes me wana do 3 cores with 4 coils. lol  Hey, who woulda thunk that the voltage would have been greater with what Grum shows in winding ratios? I would expect V in to be V out if I had just seen the setup before seeing measurements. So what might more cores and coils do? ;D Would anyone expect a 1to1 ratio with 3 cores and 4 coils? Would anyone expect no more V out than Grum has shown with just 2 cores and 3 coils???? ;) Any explanations of why out V is greater than in V??
Mags
Tito L. Oracion
Quote from: Magluvin on February 10, 2014, 11:30:44 PM
Above all, the fact that the out V is greater than the in V is the interesting part. it does seem to be a 1to1 ratio. And it is simple AC in AC out.  Now if it were pulsed or square in, then I wouldnt be so surprised. Makes me wana do 3 cores with 4 coils. lol  Hey, who woulda thunk that the voltage would have been greater with what Grum shows in winding ratios? I would expect V in to be V out if I had just seen the setup before seeing measurements. So what might more cores and coils do? ;D Would anyone expect a 1to1 ratio with 3 cores and 4 coils? Would anyone expect no more V out than Grum has shown with just 2 cores and 3 coils? ??? ;) Any explanations of why out V is greater than in V??
Mags
Well, that is basic also, the V out is not only depending on turn but on type of core and how it was wound in the core. etc, and some other efficiencies to make the volts greater.  :D
and i believe that by adding magnet we can gain additional voltage.  :D
totoalas
Quote from: Tito L. Oracion on February 11, 2014, 12:16:27 AM
Using magnet as spacer instead of paper in the center of my two e cores  proves ur point     oooooh   hhahhh   yun un
I have a vintage scope and its just a matter of time before I can make a handle ot it  thanks Bruce
.96 milliwatt output  7 x 5 w  220 v ac load 100214  yt
Tito when can you show us ur   YT   link
:) ;) :D ;D >:( :( :o 8) ??? ::) :P   TADO   RIP
Dave45
