ENERGY AMPLIFICATION
Magluvin
Without the springs in front of me, just thinking about it, if we have 2 of the springs described before, say in a vertical tube, then we put one spring in and then the other, I think 1lb will compress them each down to the 5in 1lb rating of a single spring. The lower one may compress more due to the weight of the other spring. so if thats correct, then...
2 springs inline would be like 2 batts in parallel. And 2 springs side by side would be equal to 2 bats in series, and the reasons being voltage is pressure and weight is pressure. And I suppose current would be distance of motion for the springs.  Example, 10 springs inline would take applying that pressure to compress them a longer time to do, at a particular rate.
Mags
Tito L. Oracion
The pole changing and connection adds the voltage of the battery, that is why in voltage multiplier it needs the direction to change so that it adds up isn't it.  ::)  weird huh.
Tito L. Oracion
Now lets say: we have one battery and we have three electrolitic cap of atleast 10k uf, then first connect them in parallel in the battery, then connect them in series with the battery and make a very fast and short discharge in a lots of coil in  a continous manner . do you think we can power up our house?, well that is just very simple isn't it. :)
INSTEAD OF SOLAR POWER.
Magluvin
Quote from: Tito L. Oracion on March 23, 2015, 09:38:52 PM
Hey Tito
So what would be the difference between charging the caps that way, or using a switching power supply with a step up transformer?
Mags
a.king21
Tito:     Do  you mean something like this?
