ENERGY AMPLIFICATION
0 Members and 59 Guests are viewing this topic.
that_prophet
This was given to me for the Tribulation Saints, (I ask my ABBA Father)
+ I don't think that they will have money to buy all of these items.
When this is meant to be super simple + easy to build out of odd spare parts.
All that you need is a DC motor + an AC generator of the same voltage.
One large wheel/pulley, (like a bicycle rim) + at least one mini-pulley/wheel, (a thread role)
And a few full wave bridge rectifiers = (only 4 diodes each)
The hard part is when you would have to rig up a way to connect your motor + generators to your pulleys, (glue or threading of some sort,,, you cannot weld or bronze them, unless you found a way to disassemble them or heat sinks, to keep from frying your winding's)
Quote from: lancaIV on September 22, 2016, 10:48:15 AM
that_prophet,
yes it is believable and constructable,
but there is ever a relationship between mass,RPM and electrical output !
Internal BEMF,no-/load condition, and external BEMF from no-/load=consumer
Here a german inventor (RIP) description, low RPM generator = ultra high costs
giving this "high" values: 1US$/1Wp so 1000 US$/1KWp only for the generator
+ pulley + motor + starter battery source
https://translate.google.de/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=https%3A%2F%2Fworldwide.espacenet.com%2FpublicationDetails%2Fdescription%3FCC%3DDE%26NR%3D4304132A1%26KC%3DA1%26FT%3DD%26ND%3D3%26date%3D19940818%26DB%3DEPODOC%26locale%3Den_EP&edit-text=
that_prophet
I truly do not understand the mass misunderstanding here, can't you see that evil forces are at work, keeping you from believing this Gracious Gift of God's. This was easily understood by everybody that I told this to, and they agreed that it was so obvious, that it just had to work. I will try to explain it in the same way, that I explained it to them.
   I started off by telling them that I had a large 100cm circumference pulley, and that it was connected to a DC motor. Then I told them that it only took one single spark of DC current, to rotate that large 100cm circumference pulley one full time. This would give you 100cm of moving belt, which you could then run past 1 to 10 mini-pulleys of 1cm circumference. This would give you an output of 100 to 1000 units of AC electricity, which you would run through some full wave bridge rectifiers,(4 diodes): one for each AC generator that you are using. This way you would get a lot more DC current than you would need to power your DC motor for one rotation.
   Now, try and tell me that you could not get the one spark of DC current, that you needed for your input drive motor, out of the 1000 units of AC electricity that you get as an output. Thus, you have a set of AC+DC motors/generators that run continuously, that you should be able to tap power off of, and the greater the # of mini-pulleys with AC generators attached, they greater the amount of current you should be able to coax out of you leads off of your full wave bridge rectifiers.
                        that_prophet,I like super simple thinking,too !
          odd spare parts :
          sufficient for
                                      7000
                                     70000
                                    700000
                                   7000000
                                  70000000
                                7000000000
                               70000000000
          earth habitants or want your peers an "ENDKAMPF" ? I ex(s)pect a simple answer !
I believe more in 3/4D-Print-Technology than in your peers,that_prophet !
                  Same IDEA/L,F.ree E.nergy D.evice, different way of realizing !
                               A little more realistic!
forest
It's hard to read this whole long sentence but I may answer. Yes - it will work IF you find the way to eliminate back-force, because each of this small pulleys are loading the wheel a bit.
that_prophet
http://free-energy.yolasite.com/
