ENERGY AMPLIFICATION
0 Members and 71 Guests are viewing this topic.
wattsup
Quote from: Erfinder on October 09, 2017, 10:45:08 AM
It would probably be wise for me not to digress, the discussion is about "Energy Amplification"....  It's strange, after all this time, it appears as if none are aware of the "exact" instance, when the term "amplification" applies.... specifically in the ozone patent.
We talk about Tesla as if we know him through his works, I find we dishonor him by not seeing, and thereby appreciating what he laid at our feet.....  The ozone patent is a masterpiece......mastery of which is but the first step....
Hear, hear!!!
But what does the patent really do?
Here is the problem with the capacitor. Many say the capacitor "discharges" when H connects. OK, explain to me how the capacitor charges and how it keeps its charge, too then discharge. The problem being that during Teslas' time there were no diodes to hold any charge in a capacitor for it to then be discharged when required. In the patent, the capacitor is inline between a constantly connected positive potential on one side of it, and on the other side it is constantly connected to the working primary that is connected to the fan and rotary switch turning dc motor brushes that then goes to the negative potential. So the capacitor is always connected to the source and is never left as charged so it in reality cannot discharge any more then the source itself. There cannot be a high discharge of capacitive potential. In water terms, the capacitor becomes something akin to a low volume pressure tank or better put a small water hammer arrestor. But why put an arrestor on the positive line before the working primary? It is because the arrestor or capacitor is put there because when the feed potential is reversed again when H opens, the "let's say current" can reverse back into the working primary and because of the capacitor it lands in the capacitor thus passing 100% of the working primary and by doing so creates a change in the total length of the working primary which is the real object of the patent. How to change potential in all of the primary and not only in half of it like it would undergo if it was switched in a traditional linear circuit.
Mind play. What happens if you took the capacitor out and replaced it with a nice inductive coil or even another DC motor but that had twice or three times the inductance of the existing fan motor? So you have two dc motors running on each side of the working primary. This will do the same thing as how Tesla is using the capacitor. From the positive side, the capacitor is seen as a normal wire that conducts like any other wire will do. From the negative side the same capacitor is seen as an small expansion point making sure that anything that goes to the working primary passes it completely and slightly expanding in the capacitor. Hence the more COMPLETE the potential change can occur in the working primary, the more it will impart to the high voltage secondary. Yes it is a true masterpiece. He is basically using the capacitor as a high inductance coil in series with the low inductance working primary.
One day I would like to make an animation of the circuit workings of that patent under Spin Conveyance because under the Standard EE model, that patent is just a technical mess and most likely one of the main reasons why this patent has been so misunderstood for so long. You cannot explain it with Standard EE and maybe this is one of the reasons why Tesla made it to fly in the face of the inconsistent physics eggs that were being laid by the intellectual hens of those days. Basically with this patent Tesla found a way to beat or circumvent Half Coil Syndrome which he probably knew existed but did not have any way of discussing it because the mentally of electricity travel in a wire was so pervasive, being a false notion that relegated our effects as linear travel, but there never was any electricity travel, it was always conveyed.
wattsup
forest
Quote from: wattsup on October 14, 2017, 11:07:27 AM
Hear, hear!!!
wattsup
If you make animation or better yet , video with your explanation of Tesla patent I will be glad to watch it many times to grasp the idea. Things are harder to understand with age especially in foreign language :-( It would be really helpful. I had the idea but I cannot prove it or check it, and with my very rude experiments it seems to be wrong...but I thought that maybe Tesla used the shorting coil method used by Aviso to charge capacitor to higher voltage.
wattsup
Quote from: forest on October 14, 2017, 11:28:06 AM
@forest
This thread goes back many years indeed and back in 2011 I had posted a small animation to show the simplistic nature of how both polarities of a battery advance into a circuit.
http://overunity.com/6763/energy-amplification/msg279767/#msg279767
Years later, I then did some videos of Half Coil Syndrome to show how our coils work when pulsed on one side only. This one side pulsing is the bane of our existence and includes probably 98% of how our coils and motors are used and why we will never go above COP in this manner.
I have had many years since then to put it all together under one main atomic effect of the nucleus that has been neglected ever since Faraday was "forced" to rationalize the coil and compass effect as being a field related effect. He had to include the field because our past was built on it since 100s of years before him. Academia at the time only wanted the field construct to fit the effect and help our minds grasp or hallucinate "action at a distance". But it was all faulty logic married by Maxwell to fancy numbers. This is still where we are today. Faulty or not, our toys work so who cares, right?
So of course today such a construct as Spin Conveyance is like saying Jesus was not the son of God but an offspring of extraterrestrial alien insemination. But man oh man, SC explains it all so fluently that the EE Electron and Field model will one day become obsolete. It may take 20 years before it hits the classes but the more I see this the more stronger my position is. Usually, when a construct is spawned, it will quickly die from inconsistent matching to effects. But SC fits it all. I am sure if I put this in front of Tesla in his days, he would have realized the importance and direct attribution and understanding of our effects as in this manner, instead of the Electron/Field construct he so despised just by his own natural sense of universal cause and effect. He knew it down in his gut that something was wrong with the Electron model but he had his own priorities and we thank him for sticking to them and not being overly distracted in those days. Construct modelization was not his calling.
Example problem: You pulse a nice square wave onto one side of a coil. You scope the coil and see this crazy looking waveform. You then increase the frequency of that same square wave pulse and all of a sudden you see this bland boring sine wave showing a gradual increase, peak, gradual decrease to zero then you see this gradual increase going below the zero line to a peak "negative" then a gradual increase to zero again. So now, try to explain how purported electrons traveling in a wire at said speeds that would make your heart stop, all in one direction from a square wave pulse will create a nice sine wave above a certain frequency. Try to explain that with Standard EE physics. Oh this must be one of those famous exceptions to the Standard Model. If a physics model is to have any sense of truth, how can you even accept one exception. No a model MUST handle all effects if it is to be considered viable. As soon as it fails on a major cause/effect, it has to be scrapped or modified. The fact that science has had 100s of years of piece-mealing and force-feeding our accepted science into what it is today does not make it right. It only makes it mildly palpable and greatly full of holes. But if you never consider that there can be holes, you will never even look for them.
As pulse frequency goes faster, the transformation of a complex waveform into a simple sine waveform shows us that we have reached the physical limits of a physical condition and the only physical condition that it can be is the copper nucleus' limit to how fast it can sway to an impulse and return from an impulse. If you held your hand steady while you let your index finger point up to its extreme limit and down to its extreme limit as a physical movement, then if I asked you to do that faster and faster, you will see that you cannot do that while keeping the same length of movement so the movements get shorter and shorter as you increase the speed. Your index finger just explained the same limitations in the nuclei which explains this cause/effect. It's so simple you would laugh. This same SC notion then can be used in variations to explain the physical effect of resistance,  inductance, capacitance, etc., all physical forms of effect that are today only explained by formulas and force fed by speedy moving electrons.
I had also made an animation on a Joule Thief circuit located here;
http://etherimpress.com/forum/index.php?topic=687.msg2330#msg2330
Also, two docs on SC are located here;
http://etherimpress.com/forum/index.php?topic=684.msg2326#msg2326
Sorry if my posts are long winded but luckily I don't post that often anymore. hahaha
wattsup
Jeg
Hallo guys, hope you are fine.
The bigger problem in this design is that very few people bother to test and experiment on. I also like to assume what a circuit does when i look at it, but in most of the instances there are issues that just can not be predicted.
Few things about what you miss here are:
1. There is no need for a diode but even if you use one the outcome doesn't change...a lot.
2. In this specific circuit the charging current is DC even if it can also  be done by using AC
3.  " currents with great electromotive force" is the key word
4. The phase between current and voltage is a condition which has to be taken seriously
5. Current's change of rate at key moments has a great impact on the operation.
But again without bench work it is rather impossible to see what is going on here. And as Erfinder said this is nothing else but the first step.
Wish you the best
Jeg
tinman
Quote from: Erfinder on October 15, 2017, 08:07:28 AM
QuoteIn the future, it would be professional of you to refrain from quoting me....we don't think alike, we have nothing in common...you do not comprehend the patent under discussion, and it is my firm opinion that you are only here to massage your ego, with assistance of those who are willing to oil up and rub you down.....disgusting....
Just where the fuck do you get off? thinking you have the smarts to put some one down like that.
Wattsup has helped more,shown more,and been far more innovative/creative than you have ever been.
There is only one here !stroking! there ego--and that's you-you ass clown.
QuoteTesla does a  superb job spelling out what the patent does...  I am sure you can read, but this isn't about reading it's about comprehending...  Can you see what is suggested but not communicated aloud.....  No...in this department you are an epic fail.
The only epic fail here--is you.
Fail to show anything of any use.
Fail to explain anything to anyone.
And the biggest fail--to think you know Tesla's work,and understand what he dose not say or show.
QuoteEverything following your brain fart can be filed in the trash bin.  Your ignorance and arrogance blinds you from that which matters.  Your inability to see and properly interpret the obvious is painful to watch.
Whats painful to watch,is those that i consider good people,falling for your bullshit and baffle.
All you ever do is quote Tesla,when you have no idea what the hell your talking about.
QuoteIn the example (Ozone circuit), the capacitor is charged by a DC source.....no diode required......duh....  In variations of the same circuit where AC is the source, he "diagrammatically" suggests a simple yet mind boggling method for charging AC caps to a DC potential without the use of rectifiers....  I was obsessed with the "missing rectifiers", so much so that I dedicated years to finding why he didn't use them and authorities and their minions state that they are a must...  I found the method, all that was required was that I dismiss my preconceived notions.
Another lot of bullshit that belongs at EF,so as you and your two co-horts can write a book of secrets on mechanical,magnetic and flyback rectification--all old news.
QuoteI can show you how it's done, how to charge a AC cap from an AC source to a DC potential without diodes, using a method which was well known and practiced in Teslas' time...
I can show you 3 different ways-woopty-f*&king doo.
QuoteIn exchange for the disclosure, I ask that you refrain from commenting in any thread on this forum dealing with Teslas' work!  Your theories are an unwelcome distraction
And just when do you think you earned the right to put this kind of ultimatum on any member here?
Your theories are nothing but horse shit--a continuous babble of nothingness.
Quote....If it was put to a vote.....I am positive folk would run your ass out of here, if for no other reason, curiosity regarding this cap charging method...
Those here are smart enough to see blackmail when it's presented--as you just did.
My vote is--wattsup stay's--and you take a flying leap.
You show small parts of a system to a select few,but never show the whole picture--why.
Well here is why--because if you showed the whole system,then those in the know would soon sniff out your bullshit--and your goose would be fried.
Lucky for us,there are a few that see right through your bullshit,and so,wattsup will be here to stay,as most will know what he has done,what he has contributed to,and those he has helped out over the years--not to mention all the alternative ideas he has put forth over the years-->unlike yourself,who has given nothing at all.
Up Yours
Brad
