ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
0 Members and 708 Guests are viewing this topic.
romerouk
Here is a simple way to demonstrate energy amplification. I have used this circuit with very good results and also used in the kapanadze 12 volt replication I have. D1 togheter with the right pulsing adjustment is the key to get a succesfuly working device. I hope people will understand what that D1 is doing there... I have tried to explain this before but nobody seems to understand.
Check the folowing link for more details http://jnaudin.free.fr/html/tbfrenrg.htm
ramset
romerouk
Sir perhaps another try?[at explaining]
You are preaching to the choir here!!
Thank you,
Chet
Thanks Grandma
IWD
well..I would say.. If there won`t be diode, then the fast colapsing magnetic field which release all energy stored by previsous pulse at one time+voltage induced by momentum of charges will results as current flow in the secondary. Which will have opposite polarity like before(when the tranzistor are on)
That is most effective when core is propper closed and primary to secondary is bifilar wound on.(L1 have same value as L2). Then, because in the primary, energy cannot flow anywhere, all energy collapse to the secondary and then in secondary you can measure: the first pulse energy+Bemf+voltage induced inertia of charges in the primary.
Otherwise, when you connect the diode like picture below, then part of energy will burn on it, and part of energy will burn in load on secondary.
Of course the current flow across diode and primary will also induce some energy in the secondary, but still, serious energy is lost to nothing. Coil discharge is not that strong as capacitor discharge.
Tito L. Oracion
GOOD DAY!  ;D
Well, i must admit that you're all doing a great job!.
though your work seems so complicated to me, but still good.  :)
we actually need only coil, caps, diode, zdiode and relay to complete the working device that will last for 11 years :)
Note: A.) Electricity is dual in one "CRON". so separate them then, Walla, we have controllable
              energy!
        B.) We can actually re-use the collapsing magnetic field to make an extremely strong magnetic
              field.
remember: how the nature work as tesla say about the rolling stone ice.
I think the next time i return here is, i will just congratulate all of you.
bye!
;D
forest
Quote from: romerouk on September 26, 2010, 06:12:02 PM
He he look how we are approaching Tesla method of conversion while trying to find the simplest circuit using electronic solid state parts....  ;D
