Tesla Patent 382282, and all related to his transformers/converters
Started by clone477, February 07, 2009, 04:31:11 PM
Room3327
This is a Steven Marks quote,
QuotePlease let me make another point.
Let us say that you have a magnetic field perhaps it is only a small permanent magnet.
Now, you have a single copper wire twelve inches long.
If you move the magnet across the surface of the wire from left to right at a certain speed you create an electron flow which is DC and it has a power potential based on how strong the field is and how fast the magnet is moved.
So, if you increase the size of the magnet or the speed it moves, you create a larger flow of electrons, larger as in higher voltage or more current.
Everyone tells us that the earth's magnetic field is measured as being too insignificant to generate any useable power, that is not so.
Let me give you something to think about...
If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short.
OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power
available.
If we put it into a perspective of power per inch it may be easier to
understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch.
If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire.
Understand that I am trying to convey a principal that you can understand for use in the future.
So, you have a wire twelve inches long and you can make 12 millivolts moving a magnet across it.
If you have a wire 1000 feet long and you move the same small magnetic field across the length of it you can create much more voltage potential perhaps 12,000 millivolts lets say.
So, you have managed to generate a significant amount of electric power with a weak magnetic force.
OK, how does this help us? where am I going with this?
Suppose you have 1,000 pieces of wire twelve inches long and you run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts etc.
If you connect the wires in parallel you will get higher current but lower voltage.
However, the power potential is the same whether you run the wires in series or parallel.
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can convert as much power as you wish in a given space.
Things are more complex then what I have told you but I am just trying to
give you an idea of how the technology works.
Do any of you understand what he is saying? How from this, can anyone believe that he meant he was using the Earth's magnetic field to generate power.  This is an analogy, he is trying to get us to understand how this device can generate power.  Even a weak magnetic field such as the Earth's can be made to produce usable energy if you have a long enough wire or you MOVE THE WIRE FASTER. In Tesla's converter a weak magnetic field can generate a lot of energy if it is MOVED FAST ENOUGH.  By moving the magnetic field instead of moving the wire, power is still generated just the same.  Tesla figured out that moving the magnetic field did not necessarily mean anything else had to move, the field can be moved by itself. Doing so eliminates CEMF and bypasses Lenz.  Now with no CEMF the magnetic field can move very rapidly, very easily. So in this device a small magnetic field (or low input power) can transfer a great deal of energy to the output if the field is moved FAST ENOUGH.  This device can be made to rotate the field at a very high speed, as I've stated earlier in this thread, and that high speed would cause the output to be High Voltage as Steven Marks says this device is.
As he says, to increase output from a generator you can increase the magnet strength, increase the wire length or move the wire faster.  This device is all about moving the wire faster by moving the field past it faster.  The thousands of pieces of wire connected in series is just many turns of wire in a coil. The output coils are connected as two pair and not tied together (although today's electronics may be able to do so) and each pair may be connected in series or parallel as desired for current or voltage.  The circuit potential is the amount of power that the device can safely handle and you tune the frequency (RPM) to that point so you don't destroy the device. In practice the freq. could be used to control the output power with feedback so only the required power is produced up to it's maximum output.
Tito L. Oracion
Yes its correct!
i beleive this quote of SM is gold!  ;)
and i believe that there are some more technique that we to discover, the Amplification. the wing.  ;D
God bless
otits
Room3327
@Tito
Thank you, I think? I believe you are saying you are in agreement with my analysis of SM's quote, or are you just saying that SM's quote is correct? Well anyway thank you for the response.
@All
For anyone that has not caught on to what I am saying about Tesla's patents on this device in simpler terms this is a device that generates output power based on input frequency and not on input energy.  Input frequency in this device translates into RPM of the magnetic field.  The higher the RPM goes the more energy is produced with whatever amount of magnetic field there is. And it doesn't have to be a very large magnetic field. In the device I am constructing, I have designed the field coils (4) to have 4 ohms resistance each, when connected as two pair I will have 8 ohms impedance per phase. Then I am going to drive the two inputs with a stereo audio amplifier I.C. such as a TDA7057AQ.  The input to the audio amplifier is a XR2206 function generator (which I also just built, as one thing I didn't have was a variable frequency sine wave generator in my shop) to drive a small circuit, I have yet to design, to shift the phase to one of the amplifier's inputs by 90 degrees. (XR2206 I.C. chips by the way are only $3.50 at Jameco Electronics, the audio amp $1.25 at Mouser Electronics.)  The converter coil is done, the function generator is done, and I am waiting on the audio amps to come in.
Room3327
Here is a picture of my finished Tesla transformer converter.
Tito L. Oracion
oh!
i mean, i absolutely agree with your analysis of sm quote, the more nearer to the magnetic field, the more magnetic wire and the more faster you disturb the flux then the result is better but we need to increase the mag-field so that we can put manny mag-wire.  ;D
but there is a technique that tesla is teaching us, the technique that we can produce voltage and current without using any input current and that is what we have to discover. Actually there are two,three four or manny kicks that are possible to happen when the first kick is introduced and we can do that by a good setup of the coil.  8)
THE KICK  8)
God bless
otits
