New youtube of magnet/coil "perpetual motion"
Started by Hugo Chavez, February 15, 2009, 10:00:13 AM
shubhamforme
Quote from: pinestone on April 14, 2009, 11:46:49 AM
I think you guys have missed the simplicity of this thing.
The little fan is being used as a DC generator. As it spins, the output is fed into a diode, and stored in a large electrolytic capacitor. The current from the capacitor runs through one winding of the coil and into the collector of an NPN transistor.
The second winding on the coil is fed into another diode and into the base of the transistor. This part of the circuit is what 'turns on' the transistor. As the magnet approaches the coil, it induces current into the base, then the transistor conducts, allowing the collector current to flow through the first winding (from stored capacitor) providing a 'kick' which repels the magnet.
Polarity of the coils and placement of the magnets would be critical, and some experimenting will be necessary to get the timing & polarity right.
diagram: http://www.nanomagnetics.us/projects/perpetual%20motor/perpetual.jpg
hello there....
i have seen the circuit here---
does this works ...???
because  i have tried other ones and they didn't worked....
also how can we use a fan to power this?????
please explain.... can i use a small 12v dc computer brushless fan in this circuit??
kindly explain
thanks
shubham
ramset
Thanks Grandma
pinestone
Quote from: shubhamforme.... can i use a small 12v dc computer brushless fan in this circuit??
kindly explain
thanks
shubham
In my diagram, the small dc fan is functioning like a generator. Some dc computer fans won't work as generators, but you can connect a voltmeter to the positive and negative leads to test them...spin the fan and see if the meter indicates any voltage. You could use a small dc motor as a replacement, but they usually require higher rpm to generate any useful voltage.
When the large rotor (with 4 magnets) spins, the 'fan' generates dc. By mounting the smaller generator under the larger rotor, every revolution of the rotor causes the generator to spin 4 or 5 times faster.
I have never built this device, but it's very similar to a Bedini circuit with some minor modifications, and shouldn't be too difficult to make.
Tinker
Lets add this to the Mix.
*Patent
Author   Year   Title   Country   Assignee   Number   URL
   1971   ELECTROMECHANICAL ENERGY CONVERTER WITH LOW-INERTIA SPECIALLY WOUND COIL   United States      3624439   http://www.freepatentsonline.com/3624439.html
What this is a Conical Coil Winding as near as I can figure it has lower or little drag.
Pic's here from Keely-Net
01/24/06 - Magnetricity NeoGen PM Dynamo.
Anyone want to sign on to Free patents might find more I'm out for the night.
Be Well
Tinker
magnetman12003
Hi, What transistor(s) would you recommend? Describe the coil/core diameter/lenght. Bifiliar AWG Wire size/ lenght.---- All as starting recommendations --- Working voltage of the cap also.
Input on just what small DC fan motor might be used would also be helpfull.  Operating voltage/manufacturer ??
I would like to build this and give it a try.
Tom
