New youtube of magnet/coil "perpetual motion"
Started by Hugo Chavez, February 15, 2009, 10:00:13 AM
giantkiller
@Bill
Phew...
Thanks, I needed that. For a minute there I felt my I.Q. drop watching Chelsea and not the test.
Also, I got a positive response back on youtube.
--giantkiller.
wattsup
chrisC
Quote from: ltseung888 on February 21, 2009, 08:29:37 PM
Dear Stefan,
Excellent job.
Two teams from our side of the World (Hong Kong and China) will take up the experimental testing.  They are also experimenting with the pulse DC circuits with program control.
The theory is similar.  When a magnet is attracted to a stationary coil, it will increase in velocity.  If the coil suddenly lost it magnetism when the magnet is at the highest velocity, the magnet will not be attracted back.  If the coil suddenly changes polarity, the repulsion will further push the magnet away.
One obvious technique is the use of Pulse Current which has beed successfully demonstrated in the Newman, Bedini, Adams and the 225 HP Pulse Motor.
This Dr. Altmann technique of using two coils and a transistor to do the equivalent is a great teaching tool.  It may not lead-out as much energy as the Pulse Current technique but it helps in the understanding.
Please continue your brilliant work.  We have learned much from you et al.  The World benefits because of your tireless efforts.
@Tseung
It seemed like you're ever so sure that every possible O.U device has to havr the magic Lee-Tseung witch brew?
Well, sorry to disappoint you. Looks like you really are so delusional you can't tell what is real and what is trickery!
http://www.youtube.com/user/Starcross42
Now, don't you look silly now?
Maybe you'll stop posting your Lee-Tseung nonsense once and for all. Stephan can save some hosting money on delusional nonsense. eh?
You don't need two teams, you need to take some medication. Really.
cheers
chrisC
Yucca
Quote from: b0rg13 on February 21, 2009, 08:30:54 PM
http://www.youtube.com/watch?v=9qF3v9LZmfQ&feature=subscription
enjoy
He says the fan motor charges the cap and the stored energy is used to pulse the coils. There are some peculiarities about this:
A muffin fan, like the one he uses, is a brushless multiphase device that has an inbuilt controller circuit to generate the correct phases. When you handspin one of these fans, they will NOT generate potential across the power input wires. You can not use one of these fans as a generator. Only if you remove the control circuit would you have a multiphase generator to which you would have to connect a rectification network in order to charge a cap.
When I study the video very carefully it looks like the wires connecting the "cap" to the fan are just spoof wires, they are clipped off at the fan end and do not penetrate the baseboard at all, just hot glued on. This is very obvious when you view the video full size and pause and then study the shadow cast by the wire. His finger is also eager to cover the end of this wire. You will also note that he did not bother to route grooves in the wooden base for this wire wheras he did for the coil drive wires, an obvious spoof addon at the end.
The "capacitor" seems to be sitting in a rectangular hole, a hole that would hold a PP3 9V cell perfectly. The "capacitor" is too tall for the baseboard so the baseboard does not rest on the table but wobbles about on this. If he took the trouble to route grooves for the coil drive wires then why would he have the cap sitting proud. Also in all earlier vids the baseboard does NOT sit proud, it sits flat. We can conclude that the running vids did not use the green "capacitor" as a power source.
Note:
The "cap" underneath may not be a cap at all. It looks like a PCB mountable NiMH cell, usually used for UPS in RAM or clock circuits etc. It will probably be 3.5V and judging by the size of it several hundred mAH capacity, possibly approaching 1AH. So capable of holding quite a few Joules, far more than an equivalently sized capacitor, even if it were an ultracap.
So he added some extras to his reveal in order to make it look like he was trying to feedback fan generated power to the drive "cap". For what reason I don´t know, maybe it was a token gesture to the FE community sort of like saying "see I WAS trying to get a self runner".
I suspect the original held a 9V pp3 NiCd or NiMH cell that drove the transitorised coils.
His 20min run video is now explained, it was slowing at the end because his cell was beginning to drop off.
Anyway, kudos to him "revealing" in the end,  he made a nice pulse motor with his transitorised coils with inbuilt triggers. Maybe he was closer to a FE device than he thought!
edit:
I will say this. This guys whole escapade was VERY UNSCIENTIFIC! His motive for doing this is still unclear to me?
Yucca
Quote from: sushimoto on February 20, 2009, 07:34:00 PM
Hi Yucca,
Perhaps it is thin ice for me now, because its a sensible thema
and english is not my native tounge, i will try to explain my opinion.
Are you asking all the experimenters to leave out their fingers of their devices?
Till today, i have'nt seen any selfrunning devices. Youtube's devices are full of fingers and batteries.
But besides of that, a lot of videos are encouraging nevertheless.
The explained principles are true. And maybe, with more sandwich-coils and tighter air-gap it will work.
Look at Bedini or Adams replications.Example:
One day, my son asked me a question:
"If a dynamo produces electricity by rotating its shaft and
a motor spins when you put in electricity. Why not simply combine the two by their axis?"
At first, I had to explain a DC-motor. Explaining a generator was easy, because its basically the same.
So he asked:
"So why not putting two coils like a sandwich and you have a motor and generator in one device?"
Huh. Friction losses are easy to explain, but what about Mr.Lenz, Mr. Faraday and Eddy?
I am able to explain their "Laws" but the laws are still leaving some space for creativity.
And here we are. My little son and tenthousands of OU-Researchers.
Look at Thane, Whoopy and others which are doing a great job.I dont know, where you live, but here in germany we are always seeing cars flying,
laser swords, detergents washing whiter than white,etc in our TV-Commercials.
Is that exagerating? Where is the border beetween exagerating and lying?
Have you ever hold a real BigMac as seen on the Glossy photos above the counter?
Are you complaining these lies?
This Lego-Professor is 100% true with the shown theory visualized by his setup .
He is not selling anything.
And if you feel to waste your lifetime with learning physics or by researching OU in general,
you should really not watch most youtube videos.
Youtube is entertainment and education in one.
So is his movie.
If Scotty is beaming up Kirk in a movie,
are you running to your garage to build a heisenberg compensator to build a "beam-bay" for travelling?
No, but we are all dreaming that it will happen one day.
best,
sushi
Sushi,
Worry not, your command of the English language is EXCELLENT! I am slowly learning Spanish and I would love to speak it as well as you speak English.
Yes I am very familiar with Woopy and his UCC coil idea for pulse motors, I am working alongside him and developing embedded software so that we can both search for any peculiarities in the coil:
http://www.overunity.com/index.php?topic=6727.msg157560#msg157560
My research in this very area was interrupted by this video which turned out to be fake. I guess that´s why I got a little fired up about it all.
All the best, Yucca.
