communicating Barrels
Started by pinobot, January 17, 2006, 04:00:40 AM
pinobot
To boldly stay home.
pinobot
Some variations, with only one airtight barrel.
pinobot
Simple explanation:
Barrel A is airtight, barrel B is not.
Gravity is used to pull a fluid from A to B through the big hose, when the fluid flows a vacuum is created in "a" through te mass of the fluid in the piece of pipe "c", if the fluid doesn't flow then only "b".
"d" is the normal level in the small hose, "e" is the hight the fluid has to be raised.The weight of the fluid to be raised in the small pipe "e" is less than the weight "c" creating the vacuum "a".
So it could work.
FreeEnergy
and when you do build one post videos :)
pinobot
I found a device that works almost in the same manner designed 400 years ago on Donald E. Simanek's website. :P
http://www.lhup.edu/~dsimanek/museum/unwork.htm#sinclair
It's the George Sinclair's Siphon.
It's not as good as mine. ;D
