PLEASE PUT WORKING CIRCUITS only HERE (for everybody please give a share)
Started by Tito L. Oracion, March 03, 2009, 08:19:49 AM
scratchrobot
Quote from: core on June 26, 2011, 06:18:48 PM
Note: You need to 'Roll your own' driver circuit.
Respectfully,
Core
Hi Core, interesting circuit, did you buld it? Do you heve more details?
regards
Magluvin
Quote from: Tito L. Oracion on June 28, 2011, 11:53:43 PM
In getting the peak mode we prefer the fastest one but there is always a sweet spot for that fastest point to always having the pure and strongest effect.  ;D
Cool   Thanks Teetles    ;]
So high freq is preferable, but we can do it also at lower freq.  ;]  I like.   I think Romeros coils are doing it. Bifi and the rotor gets to a speed that the pulses get the coils peaking.  ;]
Ya know Teets, Im just only now(recently)getting it in my thick head that the bifi can be a self contained resonator..
See, I told you I was slow.  Duh.  ;]
So can we connect the oscillating driver to the other many coils via cap?  Or is it that the other many coils just need to be in the vicinity of the reed oscillator?  ;]
thanks again Teets.  your puzzles are starting to look like a Picture.  lol   tell me, is it pretty?   ;]
Magsy
Magluvin
TWEETS!!!!!   HEY!!!!
Been posting tings, yes tings..     I think I found the answer.  Well I didnt find it, Its just what bruce was talking about and a thane vid and romeros ting,  yes ting, and something you always said.  ;]
Ok, I hope you will confirm, so Forest can have heat this winter.  ;]
When you say lots of coils, do you mean a many strand multifilar coil?
Magfi
core
Quote from: scratchrobot on June 29, 2011, 02:59:29 PM
regards
Yes, I am rebuilding a new version that can handle more power on the primary, mainly the transistors. My driver is a simple 555 ic set-up that also could use a revamping. As it stands now time is my enemy. Since I do air conditioning work I am a little busy and have little free time for building, however I will tell you the following:
1 - Ignore the secondary if you will, it is a Hybrid off an Eric Dollard theory I came up with.(Actually the secondary contains two capacitance's when you consider the top of the secondary to earth ground.)
2 - The meat and potatoes of the circuit is the primary set-up. Actually, I am surprised it hasn't been posted on any other forum.
3 - The primary circuit is not mine and comes from a much more authoritative source on the subject that should be well trusted.
4 - The first thing that should grab your attention is the very interesting way the bifilar coil is wound. Noticed the capacitor between the bifilar? Haven't seen that anywhere?
Give it a shot you have nothing to loose doesn't cost much to build. Note, you do not have to use a 'tube' and 'wire' like I did. A straight up bifilar works just the same.
BTW - Any chance we can keep on topic and talk about posted 'working' circuits and not imaginary circuits?
Core
Tito L. Oracion
let us just make concentrate on romero's  tech, just forget everything here its cause its getting good  ;D
