PLEASE PUT WORKING CIRCUITS only HERE (for everybody please give a share)
Started by Tito L. Oracion, March 03, 2009, 08:19:49 AM
forest
I ask myself how to avoid using diodes. If output is radiant energy could I just use ordinary diode bridge rated 1000V ? I think output will be like car ignition coil , mostly positive but with a nasty negative lowervoltage spike before . I wish it could be possible to shape coils in such way that output will be only positive thus eliminating diodes.
CompuTutor
Quote from: forest on July 19, 2011, 04:23:58 AM
...If output is radiant energy could I just use ordinary diode bridge...
You ask good questions across the threads,
but I am forced to bare myself on this one.
No one, not anyone, knows exactly what "Radiant" is.
If they claim so they are idiots, probably.
We know of it currently,
we can prove it exists,
we can use it (SSG, Etc.).
The science community,
and society as a whole
would be farther ahead,
if existance were acknowledged !
To be clear, I am not a Bedini-ite per say,
but he made his own junctions continuously.
And enough unconventional magnetic relationship experiments
to assure us he "Bumped" into and answer on the issue.
If I had to bet on anyone having this answer
it would be John (NOT the "other" guy...)
I've only seen a few raw physics posts admitting rectification,
and even fewer releases by John (Bedini) and Eric (Dollard)
concerning sucessfully rectified radiant energy.
But the neon bulb lighting off of the plastic casing of a battery
in John's vids should indicate a need for unconventional parts.
Fast-recovery diodes to detect availability might be a start,
but an over-the-counter part to "rectify" radiant is unlikely...
Again, I hate to sound like a fatalist,
but would USA allow that part to be made ???
I mean for public purchase,
not military-only release .
we need to learn to use actual matter to sort this out,
by that I mean disimillar materials that DO sort it out.
we see "Rectifiers" as silicon junctions,
I seriously doubt that is the correct solution.
Dissimillar conductive METAL matter cohesed is more likely
to be the answer to rectifying what we know-not a-lot about.
Pulses from collapsing coils do contain reverse EMF,
or as more commonly cited CEMF (Counter...),
but they ALSO contain additional energy too.
Show me a link to a component that claims to rectify
"Radiant Energy" forum disputers intending to say this is crap...
It is there,
we know it is,
we try to use it,
some succeed at it.
Forest wants to recify that,
nothing wrong with that !
Ever search for:
"Radiant Rectifier"
http://www.google.com/search?q=%22Radiant+Rectifier%22&hl=en&newwindow=1&num=100&lr=lang_en&ft=i&cr=&safe=off
Two bull-crap results makes my point
CompuTutor
I kept this seperate,
wind TWO SEPERATE windings on the outside of an insulator tube,
with a conductive collector tubing inside of the insulator tube.
Then connect the windings in series to obtain a sustained potential
between the windings to obtain the capacitor characteristics needed.
This obviously is an AC-Oriented occurance involving extraneous BEMF conditions.
forest
CompuTutor
I need it to rectify to store in electrlytic capacitor.  ;D No problem I will try what ever I find... but that is the tough problem for me...still in starting level planning circuit ...
forest
Quote from: CompuTutor on July 19, 2011, 05:35:06 AM
What did you described ? Capacitor or a coil generating only one polarity BEMF spikes ?
Btw : IMHO radiant energy,magnetic current,cold electricity,static charge,BEMF spike it's all the same , differs only in frequency of oscillation - longitudinal wave in ether aka electric field (pure) aka changing magnetic sound-like wave. The problem is exactly this = too many definitions  for the same physical effect.
