First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi duff,
did you build the V6 and posted the pic and the results somewhere???
I did build the V6 to the point and posted the pic and video like I said the results are not what expected.
I did re-read all the old post's from TT and did carefully follow even the discussion on his site as it was still open for this reason and took every detail in. But TT did not show any pics or more then his description maybe he left something out, I dont know and probably never will. the discussion was not the practical kind.
the only what we realy have is the video and explanation therefor thats why I wana rebuild this version to have a comparisson start.
TT even said that the v6 is just to train the real V 12 would be much easier what is wrong there?
I feel because I have posted my real test results good or bad now it starts here again that everybody who does not report the same results like TT would be offended thats probably why less and less guys report here anythings anymore.
I mean to lecture anybody its easy but to do it self and show is another story.
greetigns
walt
Quote from: duff on December 29, 2007, 07:22:33 PM
Quote from: Walter Hofmann on December 29, 2007, 06:31:37 PM
Hi duff,
very nice defense. I agree with you totally in regards to changinmg anythings on a replica, but what should be replicated????? V6 ??? there was never a actual result given by TT nor any picture or values, WOW.
like mentioned before I did build after the  what you call "white paper" and did not see what I should , "what should I see"????
after not seeing the results expected I started carefully to change some portion and I believe I am right because now slowly I see some resluts even if it is just less.
I believe thats the way how any new ( or very old) discovery can be replicated  during testing and understand what is happen when.
greetings
walt
Hi Walter,
I think that the most complete instructions are for the V6 and therefore what we should try to replicate. Thomas thought by releasing that information he was protecting himself. So surely it is correct.
If yours did not work then you must have interpreted something wrong.
Please go back and read the discussion several days before Dec 14.
Kind Regards,
-Duff
Walter Hofmann
Hi skywatcher,
nice clean work. somehow it seams to me that the capacitor or pipe frame has different sizes then mine because if you compare my picture there is more room at the sides for the coil's which should be 25mm in diameter.
but anyway try it I am courious what your results are.
greetings
walt
Quote from: skywatcher on December 29, 2007, 06:41:53 PM
Here we go with the basic mechanics of the converter.   ;D
The 4 mm polystyrol plates with the capacitor built-in between them fit almost perfectly around the 12 mm copper tubes.
The converter can easily be disassembled because the upper junctions are not soldered.
I have drilled 10 mm holes on the upper side to get good access to the contact points of the graphite rods, while maintaining the original construction with the wires leaving the converter to the left and right side. The holes can easily be closed by putting copper foil above them and fixing it with tape.
Walter Hofmann
I wish you all a Happy new year and lots of success.
greetings
walt
Gustav22
Hi Walter,
From your postings I got the impression that you observed certain results when your converter was placed at a certain height in the pyramid structure.
These results were voltage fluctuations in the mV range which only occurred when the converter was in the pyramid structure (if we don't consider the experiments with the magnets).
Is this correct?
If this is correct, then I would consider your attempts successful.
Thomas clearly stated in an answer to Tigrotto that without the gypsum plates we will only get mVs.
Did you try with gypsum plates?
money for rope
neptune
Happy new year to everybody. @ Walter Hofmann. We all admire you for the amount of work done, and the way you have posted results. I would agree, as I posted some days ago, that if one has gone as far as possible with a v6 and got limited results, then maybe it is time to try a v4. Keep your v6 converter, it doesn't eat anything, and give the v4 a chance. I have spent hours trying to come up with a final circuit diagram for  v4. It would be nice if anyone could post their version of a v4 diagram.
         @Duff, I agree with all you say about replication, but different materials are available in different countries, so some differences will occur. The trouble is we do not know what details are important, and which are not. Also, it is best if different people try different things. I too, remarked earlier about the graphite rods being free to oscillate. If you think we have missed something, please do tell. After all we can then consider what you say and form our own opinions.
          Somewhere on the internet, I read that water stored in a pyramid overnight boils in half the time of normal water. The pyramid used was entirely non metallic. Tests in my TT pyramid showed no difference in boiling time.
