First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Pegasus
A question to Mr.Trawoeger:It is just a casuality the the Grand Gallery of the Keops pyramid have almost the same angle of of your end capacitor?
Pegasus
Koen1
Quote from: Pegasus on November 21, 2007, 09:53:39 AM
Mine is little humor,whaiting the end of tyranny.  ;D
Maybe you havent calculated the conseguences of the new technology on global scale....
Of course I have... But to any intelligent person it is clear that oil is a dead end. That is no reason to keep pointing out that oil is excssively expensive...
QuoteIf the pyamids wil works,I suggest Mr.Trawoeger as winner of the Overunity Prize,just for his benevolence to the humankind...
Well I would like to conclusively determine whether there is actual over unity going on before we do that  ;)
And it is not as if there are no other over unity devices out there already; the utilisation of environment temperature to produce a 135% c.o.p. for example in the Zaev Capacitor array (http://jnaudin.free.fr/html/nzaevncp.htm), or the mini-romag generator (http://jnaudin.free.fr/html/mromag.htm)...
Seems to me that we need to figure out where the energy comes from; is it tapping into the potential difference between ionosphere and earth, modulated by the 4 perpendicular axis of the pyramid antenna, and picked up by the coils around the capacitor? (as described in a research paper, I forgot the url) Does it also work in a Faraday cage? Is the magnet crucial to operation? Does the circuit also work with other oscilations (and without the pyramid)? Is the buildup of charge in the oscillating circuit similar to the experiments some people have been doing with capacitors and coils in a magnetic field (which appear to show a shorter self-charge time forthe caps), or is it specifically tailored to 'hook into' the pyramids' exact energy flow? What are the charateristics of said presumed 'energy flow' then? If this is the case, does that not mean that the energy is actually coming from the pyramid already, and that we are 'only' converting it?
The theory that ionospheric charges could generate a clock-like decaying sine wave in a coil wrapped around (or, obviously, inside) a metal pyramid due to the (self-)modulations of the electrostatic potential in the 4 perpendicular planes seems like a possibly viable explanation. But accoring to that theory to get any usefull amounts of energy one would have to build it quite large. On the other hand, the energy output of the pyramid is currently only enough to run a small fan, so it's not very much, and it might well be in line with said theory.
If that is where the pyramid draws its energy from, it is not actually an over unity device as it taps into the energy stored in the ionosphere... Just like geothermal energy is also not over unity. But yes, it might be a very usefull power source...  :)
spacetrax
Hi,
you misunderstood the main point on your sketch, the salt water level is very low, so that it does NOT touch the graphit slabs. The salt water is only in the lower part of the assembly, otherwise it would be a galvanic battery, which it is not.
Cheers!
Quote from: Tigrotto on November 21, 2007, 09:34:51 AM
Apologize to all!
I'll wait !
I didn't dare to hurt nobody here.
Tigrotto
Hi to all,
Guys, please stop these messages by means of which we create confusion.
I mean messages trying to understand how to built the experiment.
I don't speak german,I know a little bit only;  but I translated all the text . Nevertheless, even if I understood all the sentence, it still miss some information.
I dare to say ( without give the name of persons to whom I spoke this day) , even among "old forum members " there is a lot of confusion regarding important details of the setup. It's the reality that can not be made in doubt!
This lead me to the conclusion that only Thomas knows all about what he posted on his site ( V6).
Untill Thomas will explain us this missing information, let's don't "reinvent" his invention, please!
I did a mistake and I understood why. I'm an impatient person and i loose a lot in my life about this! :-[
Everyone of us are "impatient". As much we're impatient , as much we risk to create confusion. And the most important point is that Thomas don't like ( my own opinion) as we create confusion.
We risk to collapse all this great Group experiment Thomas is about to start with everyone of us, not for money, but for us and for many many others after us!
All I posted here are only my own thoughts!
Ovidiu
