First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
0 Members and 33 Guests are viewing this topic.
Thomas_Trawoeger
Hello Community
we are working still on the website, and we hope to get it stable till this weekend.
Please do not register now, and don?t post messages in the Forum.
We have to change plenty of things, and so a lot of registrations could be lost!
If the Websites goes OFFLINE in the next hours or Days, you should not get panic :-)
Maybe it?s necessary to change the webscripts. We want to have the website stable if we start, and so we try different systems.
You can be shure, that we will fix this problems as soon as possible..
greetz , tom
@tigrotto: there is no chemical distruction inside the pyramide. Only the Coppertubes in the base get a little agressed by the salt.
the pyramide?s max running time was 1728 hours. (72 days) After this period we stopped the V12, because we had to disasemble it very quickly :-)
Tigrotto
@ all:
Please, read attentive:
Graphit rods have not to touch the Salt-water!!!!
If my german is not wrong!
So, it make no sense speaking about Graphite-Salt-water-Copper!!!!
If , again , graphite , don't touch Salt-Water, then what's the logic behind the "battery graphite-Salt-water-copper"?????
See please, there is a small hole on the downside of the assembly , preventing the water not to touch the graphite rods!!!!
Approfitating : Question for all of us:
The assembly is however strange because, if I'm not wrong, the 6 point ( see please the Skizze2 ) have to be connected on a plate of the small ( 25mmx140mm) capacitor, the other its plate ( of this 25mmx140mm) is to be connected to the : Earth+Pyramid Mettalic Frame.
Is this correct this my understanding?
This would mean that the assembly "hanging" at 1/3 height of pyramide is electrically connected in ONLY one point ( point 6 on Skizze2) ( this would be (+))! If this my understanding is true, this is the point where is hardly to understand this "circuit"
Pay attention: I don't dare to ask this Thomas, but you, as my German is not very good !
Regards to all
Tigrotto
karl
Hallo Pese,
die Ventilatoren ziehen aber ganz sch?n Strom.
Ich glaube 4WDC@12V ist da normal. ?ber 1000 Stunden mit nur 1V kann ich mir fast nicht vorstellen.
Vielleicht eine kleine Vorspannung die als Sourcedipol eingesetzt wird.
Interresant ist aber zu wissen wie der Wissensschatz zustande gekommen sein soll.
Das geht mich aber nichts an.
Das Jonglierprinzip wird ja gerade induziert (micro TPU).
Eine Schwingquelle (nicht die Schwingkammer) kann nat?rlich auch wenige freie Ladungstr?ger sehr oft bewegen.
Die Anregungsrichtung ist dabei interresant.
Ein Energ8iewirbel im Zentrum kann nat?rlich einen flie?enden Strom als Muster einpr?gen.
Vielleicht eine Art hom?opatischer Elektronenanreger.
Deine Kritik ist berechtigt.
Time will tell...
pese
Quote from: karl on November 22, 2007, 12:15:09 PM
Hallo Pese,
Time will tell...
Deie Ventilatoren habeb ?blicherweise 9 bzw 12wat in der Gr?sser wie im Video.
Nur kleine CPU L?ftermotoren sind ab ca 4 Watt.
Wenn hier (irgendwo in der Cu Salt Grafit Konstellation die 0,5 Volt erzeugt werden
hat das nichts mit dem "gelieferten Strom zu tun ! Wenn dem so ist (spekulativ) dann
dient das nur um die "Erfindung" an laufen zu bekommen. (Erregung /Oszillation und wie auch
immer das passiert . Wir werden es abwarten , oder durch eigene Experimente und laborieren
das herausbekommen da mit der Funktion der ersten selbstgebauten Ger?te sicher JEDEM Weiterentwicklungen einfallen.
G.P.
P.S. e#Es kann schon sein , dass (wie Du meinst) hier die Vor-nung als "Source",
dient. es kann sein dass ungleichlange Grafits?be , ein "anschwingen" erleichtern,
(so wie man das bei Inverterschaltungen auch gerne macht um ein leichteres
Anschwingen von Oszillator-Gegentakt-Schaltungen , schaltungstechnisch zu erzwingen.
Aber , wie gesagt "alles rein spektulativ" , denn lernen kann ich wie Jedermann , imm noch.
pese
