First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi all,
here are a tip if you put the graphite rod in to fill it be very carefull and hold it in the right hight and location because after the fill the rod can not be corrected or it will break I had this two times and shake the pipe a bit because if the sand is not realy packed it will compact on the bottom by filling with the salt solution and there will be a gap to the vertical portion where the rods are. oh and close the holes or the sand will run out there had this too.
greetings
walt
neptune
Urgent message to Walter Hoffman. Can you please confirm that with the copper frame inside pyramid frame, you could measure a voltage between one graphite rod and the pyramid frame, with no other connection between the copper frame and the pyramid frame Except for you voltmeter.
      If you can, then this can only mean one thing. The effect is genuine, and we can all work with grater enthusiasm. Pleas confirm[or not]
        Magpower. The graphite rods should touch the sand, they should be totally covered in sand above their tops. The lower ends should be 2mm above the saltwater level. Can someone send him a link to the diagram? My computer skills are pathetic/ laughable.
georgemay
Quote from: Walter Hofmann on December 12, 2007, 05:40:15 AM
Hi neptun,
wher you got the info that the whole top of the frame is full of sand to? I could not find it anywhere and if you look closely there are the wire connector where the wire are connected to the rod below the top ( dots)
greetings
walt
Look in the white paper for v6.
Here are TT words:
"The energy pick-up tubing must now completely (however loosely!) filled with quartz sand (.g. finest desert sand or filtersand for pools)."
George
Walter Hofmann
Hi neptun and all,
yes there is a voltage of 0.231 to 0.482V fast fluctuating DC only. the connection of the DVM is just to the isolated pyramid frame ( negative) and the copper pipe portion which is totally isolated from the pyramide center post ( I left the center pipe standing from the bottom to the top and put the converter frame with the graphite rode ( 5/32 ") on positive, no coils or capacitor on jet. the hight with max output was 220mm top of the frame.
yes there is defenitly something there what has nothing to do with earth or main power.
greetings
walt
Quote from: neptune on December 12, 2007, 05:47:14 AM
Walter Hofmann
hi george
yes the pickup tube he says but he also said further down that the top portion are just there for mechanical reason to fasten and so on.
greetigns
walt
Quote from: georgemay on December 12, 2007, 05:51:10 AM
Hi neptun,
greetings
walt
Here are TT words:
George
