First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
supersam
@all,
i keep saying look at the earth batery thread.  they are achieving much more energy than you guys can dream of without the pyramid.  what if you use there knowledge with the pyramid?  who knows you might get some significant results.
lol
sam
duff
At 14.5 ml solution, after injecting 1.5 ml in the right side, salt solution started dripping out the LEFT side so I stopped.
The following graphs illustrate what occurs with the voltage after each injection of 3 ml of 5% salt solution. The first point plotted on each graph is the voltage level before the injection was made.
In most graphs the voltages were not recorded at a regular time interval therefore the curves are not truly representative of the response. I had no idea I was going to graph these when I started. I was just trying to determine at what fill level water ran out.
The first graph is that of the initial injection. With each subsequent injection it sometimes takes hours to recover to the initial voltage.
The voltages were lower on the first graph because the multimeter was left connected for the entire time. I then noticed that the multimeter was loading the device and thereafter only connected the meter when acquiring voltages. Also, on the first graph I was experimenting with different pyramid orientations and the height of the energy pickup device. The rest of the graphs afterward, the pyramid was aligned to magnetic north and the pickup unit was positioned at 177mm.
NOTICE:
  • The peak voltage rises to a higher lever as I inject more solution.
  • Best Peak voltage.
  • Best time to recover initial voltage
  • Does the voltage reflect the degree of saturation equalization?
Note: All voltages were taken with the multi-meter positive lead connect at the junction of the left carbon rod and left coil and the negative lead connected to copper tubing.
Energy Pickup Unit:
Dimensions: 120mm x 100mm
Copper tubing: 1/2" Type M Copper Tubing
Silver Brazed with: Harris Safety-Siv 45
Carbon Rods: 0.125" gouging rods @ 90mm & 95mm in length
-Duff
duff
Thomas States:
Now with a one-way syringe inject saltwater (approx. 5%) into the left lower hole, until the first drop comes out at the right hole.
SLOWLY inject saltwater until the Graphite rods are standing with their lower ends in the saltwater-sand solution.
Too much saltwater: --- Simply , wait one hour until it has run out enough.
Too low volume of saltwater: - - - Inject more saltwater until it drops out of the right hole.
On the very important thing is that the grafitne not in salt water. (If too much water in it can be 0 power)
First, I thought also that it would be better if the inner cell with salt water is full, but only after the two wells began to slow the thing to run.
It?s really a little tricky to mix sand and saltwater before you insert it into the pipes. So follow my description, wich works best. When you fill the tubes with saltwater, you will se a very bad effect.
(The pyramide will produce only very low power for aproxx. 10-10 min. This is because there is too much liquid inside. you can see, that the pyramide is pushing up the power after the first 30 minutes. After this process it?s not necessary to refill saltwater anytime!
The most important thing in the whole construction is, not to fill the tubes with saltwater!
To much saltwater destructs the pipe, and there will be a output equal zero!!!
Then make a mixture of Water+ 5%salt and press it in the left hole. If the first drop comes out on the right, stop!!
Wait 20-30 Minutes, and turn the Pyramide slowly into north.. and enjoy the Result.
ATTENTION: It?s normal, that the pyramide will start with small energy, becaus there is shurely to much saltwater inside.
Give the pyramide time (sometimes more than 60 Minutes.. the energy will increase from minute to minute.
Do any of these voltage responses curves look like what Thomas described if you overfill?
Can we compare the voltage response curve to adding salt solution with that of an initial overfill?
-Duff
duff
Tapier21 has stated in the yahoo group that he has been able to detect/locate a hot spot  a couple of times. It seems to be located slightly off center.
It makes sense that if there is a hot spot it might not be exactly where we think the center is located being that we cannot build a perfect pyramid.
My next experimnet will be to try to detect a hot spot.
I'm going to mount a disc on the end of the PVC that I have suspended my power pickup device on with a small radial slot cut so that I can turn the disc 360 degrees with the power pickup device offset a few millimeters from center. The slot would enable adjusting the offset.
I'll adjust the postition of the device and then put all side on, take voltages readings and then move turn the disc. Height is yet another variable. Sounds like another time consuming test...
-Duff
PYRAman
I think I made a new discovery by looking at the Keops pyramid cross section. When the Grand Gallery was filled with water and in the portcullis of the ante-chamber of the kings chamber some strings vibrated by means of wind coming through the narrow channels in the walls, the whole thing became a kind of a SOUND making instrument. Over the kings chamber are the so called relief chambers, made of thick plates POLISHED ONLY ON THE SIDE TOWARDS THE CHAMBER. I thing this is a kind of multi-stage resonator for sound, not relief chambers.
What if Thomas Trawoeger used the narrow pipe on the left side of the copper pipes assembly also for INJECTING SOUND (ultrasound?) into the pipes?
This is my supposition of how it may work: by injecting sound into the pipes, the cuartz cristalls start to vibrate and being in the focal point of the pyramid (?) they convert the pyramid energy (whatever this may be) into electricity. Now, being immersed into the salted water, the cristalls DISCHARGE immediately and WARM UP the water and the lower pipe. I think the salt concentration may be higher than just 5 percent.
If this all is true, Thomas Trawoeger just played with you in his own interest, because from what I have read until now, he never mentioned sound or heat.
As a rule of thumb, when you try to find the working principle, ALWAYS LOOK AT THE EGYPTIAN PYRAMIDS, especially at the Keops pyramid.
PYRAman
Quote from: PYRAman on January 19, 2008, 05:48:37 AM
I think I understood how the egyptian pyramids worked.
So, you know that pyramids dehydrate bodies, so what if they produce HEAT from inside ?
Now, by studying different sections of the old pyramids, I noticed that all of them had wells deep underground, where from they must have extracting water, in times when the desert was fertile land and water level was near the earth surface. By some means they conducted the water through the corridors and passages, thus reaching even the queens and kings chamber. I remember I read somewhere that when they first opened the great pyramid, they found salt on the walls, the walls being also a little erroded by salt. So, here we have the salted water of Trawoeger.
I think that Trawogers pyramid produces primarily heat, and when the copper frame is heated, some peltier effect comes into play, because there are more different metalls built into the frame. Then he collects the high current-low voltage and converts them by means of spool and condensers. You notice that the coil is not made directly on the copper pipe, maybe because the pipe gets hot?
Also, when you look to his old pictures, on the first site of this thread, you see the open hole of a narrower copper pipe, attached to the main copper frame. Maybe he added salted water in order to TUNE the copper frame to the frequency of the pyramid. I dont know if the V6 has something right in it, so we could start by making the frame shown in his picture.
I also have to say something else. After I understood how the pyramid works, I wanted to keep it for myself and make a lot of money with it, but as I rejoyed at that idea, something strange happened, in my head I heard a very loud and penetrating thought saying DONT BE SELFISH! That gave me the chills and kind of scared me because of its strength, that was definitely NOT my thought, so I decided to register here and tell the solution to you all. I will build my own pyramid and try it, but some of you have already built pyramids, so you can try it first.
PYRAman
