Stubblefiled & Meucci
Started by giantkiller, March 07, 2009, 11:22:54 PM
Pirate88179
@ Freezer:
You are correct in what you stated in your post.  However, remember that we discovered that he was using pitchblende in his garden which ended up poisoning one of his kids?  Pitchblende as you may know is actually uranium ore.  Now, I don't know if this is how he heated his house and lit up the ground on his farm, maybe, maybe not.  I do know that radioactivity would accelerate any output he got from his batteries.
I know you were active on that topic so I won't repeat this stuff to you. Is there more we can learn there? 100% yes to that.  did I or anyone else learn all there is to know about NS?  Heck no!
Witts is a fraud outfit as far as my research goes, and I have done a lot.  If you don't agree, then we can agree to disagree.  I have seen a lot of your work on many different topics and I have nothing but total respect for it.  So please don't take my disagreement with you the wrong way.  could I be wrong?  Of course!  actually, it has happened before.... ha ha. (more than a few times)
I am all about learning all that we can about all of this stuff.
Freezer
Quote from: Pirate88179 on March 08, 2009, 09:03:41 AM
Yes, it's sad what happened to his son.  I believe he might have done this to get a bit more energy from the cell in the galvanic sense, although I don't believe this is where he gathered his overall power.  Back to the old saying, "transmit in order to receive."  Somewhere down the line energy was drawn into the circuit through the ground or the air.  I think the motor seems related to what tesla was doing, specifically the "apparatus for the utilization of radiant energy" patent.  Tesla also included a motor in one of the configurations.  I think this served as the on and off, for tuning.
I haven't done any type of digging as for Thrapps credibility, although he does seem to know a lot about Stubblefield and other such devices which use this other type of energy.  Could be that he's trying to make a quick buck off this knowledge, I don't know.
Check this link out, and see if it might relate.  I found it pretty interesting.
http://www.amasci.com/tesla/tesceive.html
giantkiller
I reposted this thread to jog memories and it to bring to the foreground. Remember the good days 2 years ago when threads were few before the OU crash?
We have created the forest out of the trees.  :)
A different pattern just crossed mind. We can put a propeller in moving water or moving air and it spins. I see the same pick up or reception by sticking metal in the ground. As the currents go past we can collect. Tesla stuck resonant tanks in the ground. The ground level is a dividing place between 2 earth energies. Air and ground. It's late. I think I sound abit mundane.
great link there @Freezer.
In all of Thrapp's demos there are areas for hidden things. Maybe that is on purpose and he does have something. He has all the right parts, energies, and speak.
--giantkiller
mikewatson
The presence of pitchblend in Stubblefield's experiments is interesting. In 2002 I did this experiment with thorium oxide (alpha emitter) doped galena, essentially to see if the idea that Moray used radioactivity in his experiments had any substance. It might apply to Stubblefield as well.
quote:-
Extract of email I sent to Stefan Hartmann in 2002
After reading Moreland patent application US 2003/007605 repeating Thomas Moray's well known effect, which is essentially RF stimulated radioactivity, also the suggestion that the Testatika might use similar high voltage stimulation applied to "certain crystals" yielding high output power, I have done one or two preliminary experiments.
I made some artificial galena doped with thorium oxide made from radioactive gas mantles. Firstly it seems that the effect of the thorium doping is as far as I can tell is to reduce the turn on voltage from about 0.25 V to practically zero. The crystal receiver consisted of an aerial and earth with a coil tuned by a ferrite rod between. A pair of 2000 ohm headphones and artificial galena and catswhisker where connected in parallel across the coil. The tuning was fairly flat due to the loading. The output from medium wave broadcast stations was a considerably louder with the artificial galena than with natural galena, probably due to the smaller stand-off voltage in the doped version. However reducing the phone resistance to a 120 ohm pair did not change either the signal volume or tuning selectivity. Finally I reduced the headphone resistance by replacing them with an 8 ohm min speaker 5 cms diameter. The signal volume was slightly reduced but the selectivity remained much the same. This is strange because if the impedance of the crystal detector is considerably more than 8 ohms the signal would be much reduced in the 8 ohm speaker. If the impedance of the crystal detector is low, so that a respectable signal can appear in the 8 ohm speaker as was the case, then why was not the selectivity of the tuned circuit killed more or less completely. One explanation might be that the thorium doped galena was injecting energy into the tuned circuit i.e negative resistance, as occurs with tunnel diodes for example. In this case the radioactivity providing the power. Putting two thorium doped diodes in series increased the gain more.
end of quote.
Other experiments confirm that despite conventional views to the contrary radioactivity decay can be augmented/diminished in sympathy with a suitable RF signal, effectively injecting energy in sympathy with the RF signal. There are many patents around which suggest others have discovered this as well.
Mike.
turbo
Quote from: mikewatson on March 09, 2009, 06:11:53 AM
Mike.
Nooo no no no, that is just assumed by many.
Moray used a radioactive DETECTOR.
The radioactivity was not the source of the recieved energy.
I know we can stimulate decay with RF but Moray was a diffrent story....
If you, Mike think it was the radioactive stone he found in the railway wagon that came from the mine, then explain to me why Moray used the long antenna that was spun over a lake for better reflection and the deep ground connection?
M.
