Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
Outlawstc
to whom it may concern,
i have been studying stan meyers works for around a year now and i have figured it out.. and how to explain it in its simplest form of expresion.
For every question there’s an answer, for every answer there’s a question there the same in relation but there are two differences involved to get action, distortion and clarity. When you are born, distortion of all reality is at its highest. Its simple times of life, the beginning... the mind is not full of mixed signals created from experience that happens in time... its blind. As we go through life we find clarity in many things and it gives us a sense of enlightenment and or a sense of troubles... distortions and clarity can create gain working in opposition to each other. The gain is wisdom and the truth. One step forward towards the question, brings you one step closer to the truth. Hey it may be a bumpy road but its builds character. What shows the truth? Reflection. They make us walk in circles now days, surrounded by nothing but distortion. Some of us have intuition gods people... some have ignorance the devils infantry. There is so much truth in this .if you don’t understand it read it again and again. Since each time you read it, it shall bring you one step closer. To the truth, one step closer to intuitive instincts and also take you one step away from ignorance at the same time hey its duality vice versa!! life has to many variables and complexities to predict and prepare ahead of the time in most cases.. so the only thing you can do is BE prepare for the ride 24/7.. and in the present time of relativity it seems like it might get ruff. so hold on tight and dont shit yourself. the truth is im as real as they come these days haha.. what does your intuition say? i say bitch dont judge me see its vice versa lol
thats the theory of relativity in my words.. and stans tech  works off of the vice versa duality in nature..
that is the most important basic thing i think i will ever be able to write on paper in my life when it comes to lifes actions in there simplest forms that creates our complex life. from our perspective. its the dualitys of multiple forces that paint the canvas..  stan set up a controlled environment for specific duality forces.
i hope this can make a impact on the word.. einstiens theory of relativity e=mc2.... the C squared is determine by the speed of light. which is a variable determine by resistance, like when light travels through glass.. it slows down the light due to the resistive properties.so the constant rate changes..
people dont realize that power has a vice versa.. its vice versa positve and negative happen to be light and electrons.. they make us think theres just the force of electrons.. which is false..  they do so by saying current is what establishes pole orientation for north and south.. which it does.. but theres 2 ways to skin a cat.
cheers,
outlawstc
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
h20power
Interesting,
In my studies the most simplest answer to Stanley Meyer's technology is; Under a controled state change the atmospher to one that is suitable for water combustion. The intake system of a car or most any other form of fossile fuel burning is a controled atmospher created by man to best suit combustion of that fuel. Water is no different when viewed for use as a fuel, for what happens when a fossile fuel injector doesn't atomize the fuel? That cylanders power is gone from the engine for the fuel wont burn when sprayed in by a stream. All the rules of using fuels apply to water as use as a fuel aswell, if you are to use it directly you must atomized it in a controled envirenment suitable to water combustion.
Hope that helps everyone to understand it all better,
h2opower.
ramset
Outlawstc
I actually did read that post over and over {liked it}
H2opower
Thank you for all your help here
I am quite sure, do to men like yourselves and others
THIS WILL NOT STAY A DREAM [of mine anyway] reality is so much better!!
Chet
Thanks Grandma
Outlawstc
why is snow white? is a question asked by stephen meyer on the water for fuel radio blog..
this is the best answer i can comprehend in the present time.. snow is white because it is reflecting all the energy that hits it.. why? because when water goes into a expanded state it starts to reflect. whether it be hot or cold. clouds or snow. but when its cold the oxygen forms alot of little air bubbles in the snow which makes a crystal defect.. they are like a bunch of mirrors in the snow  multiplying and reflecting.. so maybe  the silicon content in the stainless when put under the mechanical stress during manufacturing is  causing crystal defects and is like a layer of snow on the stainless.. those defects can be doped under electrical mechanical stress?  if ones doped with light when its running at high voltage  the resonant positive plate creates the variability of the vacuum constant rate of einstiens theory..  the vacuum state of light.. tesla allways said that lower frequencys are more powerfull when it comes to power generation.  its all about balance.. the word amp scares us in stans work because we think its the only form of current.. ITS not.. when producing electric you will allways have a current its a action which requires trade!!!! when electric is allways being thrown out of balance it makes the copper atoms nucleus flop back and forth.. it is creating alot of turbulance for the trade of light and electrons.. it is also causeing the solid matter part of the atom to create friction.. so wires get hot..  but when theres a balanced bidirectional flow of electrons and light you create divinity in there trades.. the nucleus of the copper lines up it poles in a capacitive manner..so the turbulant amps is what we know of as the only type..  best example.. two 500 gallon tanks next to each other.. with a  5 inch pipe connecting them with a valve for isolation... we will call them tank a and tank b..   tank a has 1000 psi while tank b has -500 psi..   when you open the valve its not just tank a flowing into b.. they are flowing into each other.. vice versa ya know.. BUT a vacuum state is a mirror state of the pressure state.. if tank a is 1000psi and its mirror tank b is -500 theres not balance for non turbulent environment.. now you have a turbulent  trade!!! which causes heat and amps..  imagine tank a and tank b flowing into each other..  vacuum flowing to pressure.   pressure flowing to vacuum.. BUT tank a has more pressure so while there trading evenly at a 1-1 ratio tank a is turbulently rolling more high pressure towards the low tank.. it creates a turbulent current towards b and there for the roll is giving it a higher quantity trade to tank b in a relative timely manner.. everything in this world is predictable with advanced technology... just not as a whole..  we can set certain controlled states like stan did which are completely predictable.. for what we need to achieve and move one step further in life.. lifes all about trading and differences with balance in life one should trade in a evenly manner with the fellow man  at the least.. that keeps a neutral environment of peace.. keeping turbulence non existence..  but as the bible says the more you do for others you shall be repaid by 2?? its because we are suppose  to be crystal defects and when we reflect  we should be like the snow and multibly in potential... but they keep us doped with toxins to where we dont react propper they fill us with negativity to where we want to absorb all the light we receive. it makes us greedy in nature.. everything i have wrote the past couple day explains it all.. life if you dont see what i see which is the ultimate gift then keep reading what i wrote.. it will bring you one step closer.
Outlawstc
QuoteInteresting,
sure i could say that is the simplest way to say it as well if you already know. not when your sharing it with someone.. more or less a statement like yours that i quoted is just trying to justify smarts. . its like your painiting is distorted and mine has detail.. the more detail, the more truth is SEEN taking away the blindness of the curtains... when you see something enough it becomes familiar and when it becomes familiar it is more easily recognized when being seen in distortion.. like your quote..
outlawstc
