Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
0 Members and 17 Guests are viewing this topic.
L505
Quote from: Loner on August 24, 2009, 06:39:20 AM
@L505
After re-reading your "Questions" several times, so I had some idea of what you were really asking, I can offer a small start.  First, there are two ways to create ions.  One is to add an electron.  The other is to remove one.
You need to add energy to pop off an electron. The problem is when you strip 4 electrons from the Oxygen atom, you have to spend a lot of energy to pop those electrons off. When you ignite the gases and the water comes out the tail pipe, you got the same energy back as what you did to pop those 4 electrons off.
I think you are discussing the water fuel cell, though. Whereas I am discussing the spark plug injector which uses stripped oxygen, gas processor, etc. Well this is one problem with Stan's devices, he never clearly separated them. Was the gas processor and stripped oxygen also used with the water fuel cell? I guess it was in later stages.
L505
Quote from: sebosfato on August 24, 2009, 06:57:41 AM
Yes there is a way to steal the electron from the oxygen atoms this reaction takes place when you start to have ionization by collision inside your cells works like a chain reaction 1 electron is liberated is recirculated by the tank and again shot in the water again to knock out more electrons.
So you are saying that some how one can take an electron away (very little energy), and then the other electrons follow without spending energy, due to a chain reaction.  What causes it, and where did this free energy come from? The chain reaction is powered by what? molecular movement? Molecular wind?
With a magnet, if you take one magnet and repel another magnet,  it does not create a chain reaction where millions of other magnets give us free energy. All the magnets are part of the strain in the whole system and you need to add energy to get passed each magnet. The magnet analogy might be bad, but this why the magnet motor and toy magnet car tracks by Howard Johnson didn't turn out, and why he made some assumptions that were false which led him to never getting his dream working.  It's still possible Stan had similar dreams and theories, and hoped one day his water fuel system would work, and maybe it never did. Maybe it did. No one saw his spark plug injector work for sure, but I hope it works. It needs to be explained though, and that is why we are here asking questions about how his device worked.
L505
Some advice for people building devices:
First prove that a remote control car works, and then you don't have to spend thousands of dollars moving a 3500 pound vehicle down the road - you only have to power a 2 pound r/c gas engine car.
Stan used a dune buggy but I'd go one step further in downsizing so that you literally do not even need a garage parking stall. A r/c car with a gas engine does not require a garage, it requires a tiny shop. It is also less dangerous if the r/c car blows up your shop, because there is only a tiny bit of fuel and all your parts are cheap to replace.
Why not use a remote control car, small, cheap, as the first prototype. Get a gasoline R/C car running on hydrogen. Then you don't need big expensive equipment - you just make the tiny water spark plug.  All the parts are smaller. For example you do not need a large metal lathe, now you only need a tiny metal lathe that you can get for under $300. All your engine parts are extremely cheap and you can work on the little car inside a small room - no need for a huge garage or barn. The costs of developing and testing on a full sized family car are horrifying.
sebosfato
I'm going to try it over and over again this way at least meyer and many others claim that it could work using resonance.
Meyer tried to fool everyone making people think his vic was resonating from theory about lc circuits it prove to be wrong and lc circuits prove to work as i said.
The is no voltage with no current. ok if you could use a 1 pf capacitor and 10000henries inductor for say you could have 40kv 1 ma recirculating but give me a break this is not even possible to work with this values.
So what i say must be right the values are quite possible the voltage is similar the input current is similar so i think to have understood where he tried to fool us. Ok i didn't have tested it yet. but have you ever saw anything about what i'm saying on internet? no
not even i
so why?
Meyer protected his technology very well under a name Resonant cavity witch means very high Q tank circuit.
So believe me or not is your choice i ask for money as i finished all i have and now is difficult to get more and as i need to test this i find is fair to ask to people in internet that are working or would like to work or just believe its possible or at least believe what i'm saying is true to help me as if it comes out will be good to everyone.
A little car is much more difficult because i think you need at least a min production to achieve the chain reaction i'm talking about. its called collision.
http://www.britannica.com/EBchecked/topic/488507/radiation/28820/Particle-aspects-of-light#ref=ref398827
http://www.sayedsaad.com/High_voltge/insulating_gases/insulating_gases_3.htm
My thread for donations and more informations http://www.energeticforum.com/renewable-energy/4617-stanley-meyer-true.html
L505
Quote from: sebosfato on August 25, 2009, 06:23:55 AM
Open your own thread and stop spamming your money requests in this thread.
No one needs any money if they know how Stan's device works. People that need money are the ones who don't know how Stan's device works, so they need lots of money to fart around and figure out how it works using experimentation instead of understanding the theory.
EITHER THAT or you are looking for cigarette/bread money - go get a job at a grocery store.
