Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
kolbacict
As I say, only once did I manage to put a high voltage into a cell with water.
And even in general, one wire !
https://www.youtube.com/watch?v=uM8d3SEgLI8
This video, filmed more than a year ago, was lost. I found it yesterday.
As you can see, the capacitor is charging from the other two plates.
Up to about 1000 volts. And so that it does not break through, the arrester is triggered.  :)
h20power
Quote from: kolbacict on May 23, 2021, 01:51:38 AM
In general, where should they come from, these high-frequency oscillations?
The thyristor opened with a control pulse, at the end of the half-wave of the mains supply voltage (50 or 60 Hz.) It closed.
p.s. Maybe the dimensions of the electrodes in your picture are in inches?
p.p.s. I also wanted to say about your vacuum resin. I was repairing CRT TVs.
Sometimes it was necessary to insulate a burned-out high-voltage wire till 30kV.
No cambric, PVC tubing, duct tape could do it.I came up with the idea of using ordinary silicone for this.
Maybe it will work in your case? :)
The high frequency oscillations come from the 9xb part of the circuit as that's the part of the circuit that is for tuning things and yes the dimensions of those electrodes are in inches, sorry about that but we don't normally use the metric system here in America.
As for using silicone it would have to be like water or oil in it's viscosity as it must replace the air in the gaps between all the coils in the transformer bobbins. Air is the enemy of these high voltage transformers as it will ionize and the current's path to ground can easily flow through ionized air and bypass all of that resistive wire. I lost a lot of transformers learning that lesson. I do use some of that type of silicon on some of the solder connections to prevent the air from becoming ionized along with some wire rated to take the voltages this technology works at.
Now if you look at the waveform in the picture imagine the part that does do negative is reflected like a mirror image and subtract all of that out of the positive voltage and that is what's left over that will pass through the water bath heating up the water in the process as it's just normal electrolysis being done by pulsed direct current. Only when the waveform is balanced will the voltage be allowed to do the work of breaking the bonds of the water molecules by way of ionization of the atoms electrons causing them to eject their electrons which is the glue that holds the molecules together in the first place. Take away the glue, IE electrons, then the molecules simply fall apart and in this case that would be hydrogen and oxygen gas atoms being produced on demand by simply raising or lowering the voltage being applied to the water fuel cell.
And note once you have a sustained arc between the plates of the WFC the show is over as there will be no more potential difference between the plates to ionized the atoms getting them to eject their electrons. So, no "Catastrophic dielectric failure," as Peter Lindemann was wrong.
But remember I went back to Meyer's old stuff to follow in his footsteps to see if I could learn this technology the same way he did and in the end I did what I set out to do which was to get at the science behind this technology. Once I understood what was going on I went back to working with the voltage intensifier circuit and abandoned the 8xa/9xb/9xd circuits. But I did figure out to have better success with that part of Meyer's technology the smaller the space between the plates the better it works and yes it will be all sparkly when the cell is running just as seen in Space Man's videos.
Well, it's getting late night night all,
Edward
kolbacict
https://overunity.com/7030/stanley-meyer-explained/msg557508/#msg557508
This is about my last video.
it seems that it turned out so to create at least some kind of high voltage in the water.
Or maybe I'm wrong. All parts, starting from the high-voltage terminal of the transformer, are isolated from everything.This idea was inspired by the picture below, a certain Strebkov.
But I did my own way as always.  ;)
p.s.
QuoteThe high frequency oscillations come from the 9xb part of the circuit as that's the part of the circuit that is for tuning things
I assumed it. This can be shock excitation by a sharp rise front when the thyristor opens.
But in other experiments I have observed only two or three free vibrations at best.
h20power
Not too sure what to say when you show me things like this as you have totally moved away from what Dr. Dingle, Stanley Meyer, and others have done. The reason why I shared the science behind this technology was so that all of you would know the end goal which is to get the atoms to eject their electrons. Why? It is that action that breaks down the water molecules into their component atoms. That's the end goal of doing all of this as this technology is mimicking how a thunderstorm breaks the bonds of the molecules that are present in our air supply. The reason why I say it that way is a thunderstorm will break down any molecules that gets sucked up inside of it when it is producing high voltage potentials as it breaks the bonds of Oxygen, Nitrogen, Methane, Carbon Dioxide, water molecules, and many others.
The reason I have shared all of this with you folks is so that you know what it is you have to do with this technology and why. This is the end game of doing all of this to remove the electrons from their atoms as that act breaks down the molecules they have moved to form.
When you show me things like that Kolbacict I have to question just what it is you are trying to accomplish? The reason being is it seems like you didn't get the message of what the end goal was which is to get the molecules to breakdown into their constitute atoms by way of ionization. There are no magic frequencies but only a set of rules for RLC circuits and Standing Wave frequencies and noticing that when at resonance the inductors act like very large resistors and the tubes vibrate a lot. This is the science behind the technology so I have no idea what direction you are heading in or what your goals are. I've done the grunt work and shared my results with everyone as that's the science behind the technology in that it's mimicking a thunderstorm.
These two circuits are the same and the goal of the electric mimicking of a thunderstorm is to get at the electrons of the atoms that make up the water molecules using voltage potentials and not current flow like electrolysis does. You see the only reason I shared this information was so that people would know just how this technology was breaking the bonds of the water molecules scientifically. You see main stream science is running around telling people there is but one way to break the bonds of the water molecules and I now there are millions of species of plants that totally disagree with them.
kolbacict
Hi.
But what an elegant way I suggested as a replacement for a high-voltage differential probe.
No doubt, it is needed to observe the signals on the cell. But if a person has no money, but a lot of junk, as in the picture below, You can apply this signal directly to the deflection plates of the CRT.
A few kilovolts of common mode voltage on the plates  will not damage the tube.
And only the differential signal will deflect the beam.
I'm really good, take me into you ... :)
