Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 50 Guests are viewing this topic.
Omnibus
Quote from: plengo on April 04, 2009, 01:29:35 AM
I can demonstrate that this last video from Mylow is a hoax.
Download the sound modified from his video here (http://www.overunity.com/index.php?action=tpmod;dl=item257).
Listen that at exactly 12 seconds you will hear  a kind of air release sound. Watch the video now and pay attention to the same 12 seconds and notice that the motor accelerates at 12 seconds right at the moment the air sound is released.
Fausto.
ps: video: http://www.youtube.com/watch?v=-zqW88astyQ
Can't discern the acceleration at the 12th second with a naked eye. I hear the whizz but the acceleration of the rotor isn't evident to me. Can you enhance the voices at the background and find out whether or not the words are said in reverse? That might help.
Omnibus
The best thing would be if @sterlinga can send those exact stator magnets to @queue and @CLaNZeR.
jester
Quote from: queue on April 03, 2009, 08:01:15 PM
Depending on which way you rotate the rotors :
At the start of each rotor array segment there is a small wall you have to push through to get started.
rotor N meets stator's N = (wall) repulsion.
As the last magnet in each rotor segment moves past the stators S side and out of the stator's field - it get's pushed away by the same amount you had to push to get in to get started moving.
If you flip the stator 180 degrees - the rotors want to go the opposite way ..
Hope i haven't just confused you completely. :-)
Cheers
Q
Would like to mentions some of my obsevation -
POINTS
1. @ 2.21 http://www.youtube.com/watch?v=sPDXsrrs398  in his first set of three the gaps do not look even. One magnet looks slighty angled. in some of his others sets the gaps look slighty different as well. His 4 magnet set is not even  @ 1.21 last magnet of the set looks angled as well.
2. his motor seems to accerate nicely in and throught the sets. In these videos you see acceration and deacceration in the sets of magnets as it hits the various flux points. I am wondering where you see deacceration is were the gap should be (or another magnet as clanzers video on point 4)
http://www.youtube.com/watch?v=QiM75SFpQdA&feature=related
http://www.youtube.com/watch?v=tBWXyE6zLdU&feature=related
3. Myow posted a vid showing he has magnetic wave on his wheel
http://www.youtube.com/watch?v=T2VX89gJcbU
I guess the basic question - Can you exit at the top of the wave and enter at the bottom due to the gap and the sets of magnets(including pehaps different spacing you have between each magnet in a set) you have.
4. In Clanzers video http://www.youtube.com/watch?v=bHYWBXPVSO4&feature=related he added in an odd magnet with a different spacing to clear the gap.
One approach could be to find what configurations gives you the fastest exit from one set. A set of 3 magnets, a set of 4 magnets or 6 and the spacing between each of the magnets in the set with flux points taken into considerations. Then again with flux points taken into consideration what gap gives you the least deacceration moving into a set.
Again from point 3 Myow first set 3 magnets the gap looks slight closer on his last magnet. might be giving an added push out. I think you would need to build up your wheel checking that your wheel as a whole has acceration as you add each set of magnets. don't go by what you have done before if there is deacceration after a set change the gaps or number of magnets in the set. Mylow has said symetry is not important gapping is.
Chase212327
Here's a set of Relative Sizing and Spacing values, based on my estimating equations.  It's driven off of rotor width.  You can use these equations/values to be sure your magnet set is roughly similarly matched to the set Mylow used in his Original Running Motor.
Chase212327
slipstream
Quote from: plengo on April 04, 2009, 01:38:12 AM
Fausto,
Your analysis is compromised.
http://www.youtube.com/watch?v=JpSjHJe6rXQ listen at ~2:30 a very similar "air release" sound ...his steam heater.
http://www.youtube.com/watch?v=TDgPC-tjwww his other silent video also indicates a clock in the room with a consistent ticking.
leave it to those attempting replication for evidence as to success or hoax.
