Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 47 Guests are viewing this topic.
lumen
Because this is about the end of the Mylow HJ design and everyone is about sure that is does not actually work  (Including me), I have only one theory as to why it could possibly operate if it actually did.
We all know that simply passing magnets over other magnets gains nothing! But the thick aluminum plate CAN provide a purpose as I am about to state.
Because the rotor magnets are mounted to the aluminum plate, the field of those magnets pass into the plate, and we will call it the south pole.
As the rotor turns and the magnets approach the south pole of the stator, the field is pushed deeper into the aluminum plate at a slow rate that does not cause much resistance besides the fact that most of the field is already into the plate.
Then in the short span as it passes the south pole to the north pole of the stator, the south field on the rotor jumps to the north of the stator. At this point the field retained in the aluminum also is attracted to the stator and provides a free additional pull that quickly dissipates. The rotors south field pole does not return back into the aluminum plate until it gains distance from the stator and it does this at no cost because the magnet itself pushes the field back into the plate far from the stator.
All other magnetic reactions are equal and neither help or hinder the rotation. The concept is like an induction motor with an aluminum rotor.
If I was to try this replication, I would base the design on this concept.
HiggsField
@chrisC
You idiot. Higgs Field is not a person it's a force. By the way Easter is a pagen festival, (a.k.a. Eastre),  the Great Mother Goddess of the Saxon people in Northern Europe.
joe_1001101
Quote from: nyctuber on April 10, 2009, 05:40:11 PM
The first videos mylow originally  posted (and subsequently removed) used this bar magnet setup, albeit with a different stator position.
http://www.youtube.com/watch?v=qF8fP5K8D1g
I believe you can see how he jump started the "self-running" motor from an example in this video at 1:02.  (not talking about a little nudge)
It seems likely that in the so called "working device" video, while always being zoomed in to the stator, he started the motor manually at the shaft assembly with his right hand with enough continuous force to let the flywheel effect take over till the end of the video.  Remember after numerous requests, we have never seen the device start up from a wide shot showing everything.  Only after it was spinning did the camera zoom out.
Joe
HiggsField
@joe_1001101
This is a pointless post. Who cares how he did his initial fraud, the fact that MYLOW has started posting again as if nothing had happened previously is proof  that this is a fools errand.
Chase212327
Moderator,
RE:  "You idiot."
Are personal attacks and name calling OK?
Quote from: HiggsField on April 10, 2009, 09:51:32 PM
@chrisC
