Energy Receiver
Started by Big, January 24, 2006, 11:10:06 AM
But let us come back to the basic theme "energy receiver":
Visit for example the webpage of Mr.Thomas Cosby,
http://www.geocities.com/cosbytech/stock.html
Cosby Technologies Inc.,
a person,involved with thermodynamics since over 40 years !
My first contact with him,telephonical,2001 !
Sincerely
? ? ? ? ? ? de Lanca
Aha, ja rechtsdrehende Kreisprozesse !
diue Konvertieren Umgebungsw?rme in mechanische Energie !
Gut !
Yes, right turning energy cycles which convert  latent suroundings heat
into mechanical work, ! Genuine !
This system only needs a thermal difference/voltage of 80 degrees Fahrenheit !
So the combination with a conventional heatpump more heatchanger would
give a thermodynamic-cycle Transformer !
Or,as second possibility,to grave in the absorber in desert sand
-sand is a good heat accumulator- !
Sincerely
            de Lanca
First we have to find a circuit, where we can see an amplification
of these kicks.
Let us just calculate:
If we have a power supply with 10 Volts and we pulse
this 10 Volts for 1 microseconds ( 0.000001 seconds)
onto a 100 Ohm resistor, we have spend 0.000001 Wattseconds
of energy from the powersupply.
So if we have a toroidal circuit with 100 Ohm
impedance instead of the resistor and we
can get the output pulse, which is magnified by the kick
rectified and stored in a capacitor, it needs to have a voltage on a e.g.
1 uF cap of at least :
V= (2x Wcap / C)^-1 = 1.41 Volts
to have the same energy as the input pulse !
Now all higher voltages on the 1 uF cap as 1.41 Volts
from a single 10 Volts input pulse 1 usec long will
show then an amplification of this pulse.
So how can we generate such a circuit, that will
have a higher voltage than 1.41 Volts ?
Thanks.
Regards, Stefan.
When I see such a question I think,at first,:
who was for the AC-industry(primarly Westinghouse) more important:
Karl Steinmetz or Nikola Tesla ?
Sincerely
p.s.: When the Torribio Bellocq Analogon is real(hydro current~ electro current)
       then there will be also the right-experimental repeatable-answer !
       Aber nicht mehr heute frueh,keine geistige Konzentration mehr !
