The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
Magnon
Quote from: Chef on April 01, 2009, 04:49:18 PM
I  really enjoying your posts.
Could you maybe tell us more, how do you think the earth magnetic field is different on the southern side?
Direction of the earth magnetic field on earth surface is different on northern and southern side of the earth.
Therefore a magnetic field  direction over the TPU is different, depending if TPU is moved to northern or southern side of the earth and if TPU is not turned around.
The total magnetic field consists of field made by coil in a TPU core + earth magnetic field over the TPU.
There is no need for strong guide field. The created guide, nested cylindrical EM field can be weak, it starts to suck energy from the environment and run with a gain.
--Magnon
Tito L. Oracion
Hi everyone
A message of concern, i feel that they are pushing us to buy tubes  ;D
Yes i agree it is a good current producer
but what i see is that tube is not the real answer  ???
I smell something fishy, what do you think?  ;D
actually we can make our own homemade tubes using auto bulbs, just open it  put some needed material of a triode then thats it no need to buy just think. don't forget to use epoxy to sealed it again  8)
Magnon
Quote from: Chef on April 02, 2009, 04:41:39 PM
Does the magnetic inclination cause frequency change in the device, so the circuit have to follow the direction of the field, when we moving to different places?
The earth magnetic field strenght changes in between 0.3 Gauss to 0.6 Gauss, depending mostly on latitude.
To demonstrate the magnetic field effect on electron spin precession frequency, here is a calculator for this,
http://www.gamma.ethz.ch/online/esr/vcalc/index.html#ESRCALC2
You can also use Excel TPU phonon calculator for this calculation.
If you have a 0.6 Gauss earth magnetic field, it gives a 1.6 MHz spin precession frequency for the electron.
This means that TPU must be tuned so that the local earth field strenght is calculated in a design.
Typical applied total magnetic field strenght in a TPU seems to be around 0.22T, this gives about 3 cm wavelenght ( 6 GHz ) for microwave emission.
Because every unpaired or free electron works as a small transducer, when wobbled by acoustic wave with a same wavelenght, there is not one, but a huge amount of small microwave transducers in a TPU.
The electron spin precession axis are aligned parallel to applied magnetic field and the direction of the microwave radiation emission follows this direction. So, if TPU is on the table in a horizontal position, the microwave radiation direction is vertical.
To your question, the electron spin precession  frequency can change about 2-3 MHz in a TPU, depending on latitude and direction in between TPU and local earth magnetic field. This can be enough to off tune the TPU
--Magnon
giantkiller
Quote from: Tito L. Oracion on April 02, 2009, 10:41:26 PM
Hi everyone
The magnetic field around the conductor is a tube. ;D
--giantkiller.
Magnon
Quote from: forest on April 02, 2009, 01:39:12 PM
maybe
E) divide signal into harmonics and let them grow indepedently, then collect all
Some answers to your questions,
1. How to amplify small source of watts?
Build a guide EM field to compress and suck the energy from the environment.
The environment is full of charges and ions, and spacetime itself has an electric nature.
Collect and compress this energy.
If you build a nested cylindrical EM field, then the charges, that are under the influence of the nested EM field, are sucked into system and can not escape. Use this collected energy / spacetime compression .Spacetime compression means that the local time is curved, compared to average spacetime on earth surface.
2. How to make a controlled loop accumalaiting energy?
When you play with a microwaves, the wavelenght is on cm range. This means that one turn antenna can be used to transfer a lot of energy ( collector on TPU ). This is what happens with a TPU.
There is a phenomena that explains the TPU and it is a magnetoacoustic resonance effect, that is known since 1960. But if you tune this frequency so that it creates a nested cylindrical field without subharmonics ( prime numbers of waves on devices circumference ), it starts to suck energy from the environment nearby.
--Magnon
