The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
forest
"Squeeze the hose"
Take two perpendicular forces capable of pushing charges on surface.Arrange them against each other but perpendicular to wire surface.Then move them synchronised along the wire surface.There is longitudinal action of two opposite forces in balance.
This is my exact interpretation of "squeeze the hose". If you imagine a hose filled with water and your two fingers acting on hose in the same point, then you will easily see how sliding fingers in such arrangement on hose will push water inside in one direction.
Now we only need to find how to produce this effect.... ::)
otto
Hello all,
@forest
to move them along the wire surface gives NOTHING!!!
Guys, think a little bit.
We are squeezing the hose for .....how many years now??
We have the collector(s) and have the controls wound around this collectors, all around the circumference. Or not??
Now, if we pulse the controls we have squeezed the hose. Or not??
As you see we are already doing this.
Result: nothing special.
Read "dfros" posts.
Otto
PS: as Im older Im more and more "blind".
BEP
Quote from: otto on April 10, 2009, 04:06:49 AM
Hello all,
@forest
Read "dfros" posts.
Otto
Yes. Many have squeezed the hose. My question is which hose?
And if there is, at first, no hose? --- Amp probe seeing current (or simply a powerful magnetic field ) in the 'air' within the TPU....
I think we should stop squeezing the cores. I think the TPU -is- the hose and the water flow is vertical but twisting as it flows.
Anyone unfamiliar with @dfro's posts? If so, stop, read and understand.
BEP
wings
