The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
Antimon
Quote from: forest on March 31, 2009, 02:28:41 PM
Now we know what is used to prevent runaway situation.
I think its the ONLY possibility to use feedback without a runaway event.
And i think that also in the SM devices they act as a magamp not for pulsing applications.
A.
BEP
Quote from: wings on March 31, 2009, 03:09:46 PM
Electrical oscillations without employment of electricity?
http://www.b-kainka.de/bastel87.htm
Wonderful little circuit isn't it?
UHF Triode/Tetrode configuration. Demonstrates the main difference between tubes and solid state devices,etc.
I built a 900 mHz walkie-talky in my youth that used this circuit as the receiver section. The only variation was it was a regenerative receiver. The tubes were the Nuvistor variety. The antenna was a 1/2 wavelength bare copper wire at 915 mHz.
Edit>> Just imagine a magnetostrictive zero voltage oscillator. All you would need to start it would be an impact or placement of a magnet to put torque on the core.
wattsup
Ahhhhhh. I need to take a breath of fresh OU air.
Notice parts of this forum is going to hell in a hand basket.
OK wattsup, calm down now. It will pass.
Can I take a right hand turn here for a moment regarding the center toroid in the FTPU and the advent of the device "running with gain".
For something to run with gain, something else has to act as the totalizing storage device otherwise I imagine that what was gained will be quickly lost. So where is there any possibility to reach some level of gain in the FTPU. Obviously those very small capacitors would not have enough uF to provide anything substantial, Also the outer coils and the two rings would not have enough inductance to act in any way as a storage component. So what does this leave.
Now during the demo, we can clearly see the voltage gradually rise then stabilize to about 60-62 volts so there has to be something acting as a power tank otherwise the complete device has to run with total production available like a flat capacitor or a flat battery.
We also know that SM was rather fond of Tesla although his comments on Tesla were rather few. IMHO.
OK so here is a scenario. Take 1. Action.
The center toroid has two coils. You put one of the coils is series with the outer coils and call it the coil of high inductance (just for arguments sake - lol). You take the other toroid coil and put it in series with the two outer rings and call it a primary coil set or the primary working coil. Now you simply make a set-up similiar to Teslas' Ozone Patent (I know I know) where you have the high inductance that is used to charge a capacitor, that then discharges into the primary of the working side. But what happened. There is no working secondary. No need, the coil of high inductance that is on the same toroid core then becomes the secondary that recharges the cap and the cycles continue back and forth on the same toroid and as the toroid core becomes more and more saturated, this makes more energy transfer from one side to the other.
I have been trying to make energy exit the system into a cap tank, when I think the answer is to keep the energy inside the system and make it grow.
I have already seen the outer coils are able to also provide mutual coupling which would aid in the cycling and also aid in "running with gain". The output voltage of the TPU is just a function of the maximum ability of the coils to maintain their mutual maximum stress levels.
To see if this effect is possible, I think I will have to start with a very low voltage source that would be far below the maximum saturation point of the core but enough to energize the copper masses. Only in this way could you actually see the effect otherwise it would be lost with higher starting voltages.
OK I will stop now and head back to my workbench. lol
I can breath now. Pheewww.
Keep well to all.
zerotensor
Here's a sketch for a simple experiment.
I picked up a spool of welding wire at an estate auction; it has a soft iron core and a copper coating-- hopefully I'll see some noteworthy effects, if i can ever get around to actually doing it... (my lab is a total wreck).  In the meantime, anyone else care to have a go?  GK, perhaps? seems to be right up your alley... anyone?...
Anyway, it's a pretty simple setup, and may yield some interesting results.
-Eric
Thaelin
@ BEP
   Thoes frequencies were relative just to the point. The actuals were
                Fundamental    35705
               3rd harmonic     107115
               5th harmonic     178525
               7th harmonic     249935
This is where they would run for the 15".
The pdf is 88k so I will try to tag it on here. If not, I will up the upload area
Its name is 0903_Harmonics.pdf
thaelin
On an added note, funny how when you add the odd harmonics to a fundamental freq
how it goes from a sine to a square wave.
