UPDATE: Testing the Perreault Valves
Started by Doctor Whodini, January 26, 2006, 12:34:35 PM
Doctor Whodini
Hello all,
http://www.intalek.com/Index/Projects/SmartPAK_xPOD/SmartPAK_xPOD.htm
Figure 6 shows a variety of valves I've been testing out on my Wimshurst generator. Its interesting to note that the my largest 2" dia. valve displays the greatest effect. The valves shown range in size from 1/2" dia. up to 2" dia. The capacitance of the 1/2" dia. valve is about 5.2pf.
William S. Alek
Exploring Gravitational and Inertial Mass fluctuations,
Radiant Energy, and Temporal Anomalies
http://groups.yahoo.com/group/intalek
  INTALEK, INC.                        PHONE/FAX: 219.924.2742
  3506-43rd. Place                            EMAIL: mailto:wsalek01@intalek.com
  Highland, IN 46322 USA  HOME PAGE: http://www.intalek.com/
Dimasen
Is it really easy to manufacter this Perreault Valves?
Steel pipe, tungsten rod, some isolator is it enough to produce P.Valve?
And what is the name of gaz uses in Valve?
Doctor Whodini
Dimasen,
A 7" long 3/32" dia. pure tungsten welding rod costs about $2.50 ea.
A 4" long 2" dia. steel pipe, pvc pipe fitting, clamp costs about $10.00.
In other words, it costs under $15.00 to build a "complete" Perreault Valve!
Dobermann
Quote from: Doctor Whodini on January 26, 2006, 12:34:35 PM
Hello all,
Great work!
It will be good to make your p-valves experiments data available to public. As I understand the excess energy produced by discharge inside valve comes from e-avalanche effect. So what kind of gas exists there, air ? It should produce a lot of ozone during discharges I think. Does tungsten rod get consumed on the long run ? Also 2" dia pipe requires the maximum voltage to initiate discharge along with the increased distance between pipe and rod, so its obvious that your 2 inch valve will show the best energy kickback (more air molecules ionized).
Please if possible post the data measured from experimets, like Ein, Eout, etc.
Thanks!
hartiberlin
All, try also with copper pipe and graphite rod inside the copper pipe.
The Newman machine did work best with these materials and had the maximum
back current pulses only with this material combination.
Although they did not try many other combinations..
Regards, Stefan.
