One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
gadgetmall
Quote from: jonnydavro on June 25, 2009, 04:25:06 AM
@Gadgetmall.Hi Al.I have found also that no two snake eggs are the same.I have some which refuse to spin on low volts also so it really is a lottery with these.With your three sets you may get a vertical spinner but if you don't,let me know and i will send you some.Regards jonny
P.S If you get the chance Al,pop over to the energetic forum as there is also a thread on this motor over there and i am sure everyone there will be interested in your experiments.Many thanks Jonny
Well the Snake eggs came in / NONE OF THEM WILL SPIN AT ALL ??? out of 8 snake eggs only the one shown will spin at all . that is strange but the new magnets will not even wobble or try to wobble spin . Well i got balls with them also its sets of two snake eggs and two one inch balls . Lots of magnets . I also got the Cylinder magnets . they wont spin either ?? I have did a few more test . The Current Draw is 1 .1 milliamps at 5.5 volts and the secondary looped feedback to source is outputting 5-6 milliamp back to the battery . Its a Sure thing that this one is producing more current out than it takes to run it . only thing is one magnet works out of 15 magnets  :(  Hey i don't care . Cap test next i promise , i juts cant leave it alone and wanted to do a few more volts amps test before i go to ultra cap .. here we go !! Ok Just Started the Ultra cap test . I have TWO 650 farad 2.7 volt caps . the total on the two start voltage is 4.32 @3:30 pm est 7/3/2009 . i'll check in in one hour . This will give the story as caps done lie .  .. Ok its 4:30 . the caps are still at 4.32. I'll check back in one hour.Ok its 6:36 volts still unchanged at 4.32 . I'll let it run until wither i see it drop or rise . If Neither its a selfrunner as these caps take a lot of power to charge .i need a meter with 5 digits instead of 4
Gadget
jonnydavro
Hi.I decided to extend the twin magnet rotor and add a third magnet at one end to see if i could extend the magnetic field by interlocking the fields off the top and bottom magnets and i tested the field with an orbiting satellite as it is quite good at showing the extent off the field and the satellite would spin all the way from the bottom magnets to a height above the top magnet.Here is a pic of the rotor and a vid off the test.Regards jonny
http://www.youtube.com/watch?v=WwRwZYarBHc
@Pirate.Hi Bill.There is a dead spot at the centre of the coil when the magnet is dead centred as it won't trigger the transistor so this is why the magnets run of centre over the windings best.I came up with the twin magnet rotor to try and negate this dead spot and utilise opposite sides of the coil at 180 degrees.The suspended idea is something that Xenomorph and El-tigre have been working on.The negative amp draw is interesting.It only happens for a second or two when i move the rotor sharply towards the coil but it is quite a high negative pulse and i have not seen this before.When i do this the rotor slows (maybe Lenz)but doesn't stop so its as if it is inducing a voltage in the bifilar coil but i am a bit puzzled by it.Regards jonny
p.s. Thats a great new thread you have started on the Georgian earth battery Bill.I must admit i can't keep away from it.Nice one.
@Gadget.Hi Al.I was thinking about your motor today and wondering how it was doing and i am glad to here it is still going good.I think you have got something special there Al as to get a snake egg going on that kind off draw is pretty amazing in itself.The best i have done is 1.34v at 4mA.I can run a cylinder at less than 1mA @1.5V so i was kind off hoping these would work for you.
Like you say,the cap test will tell the real picture but if its outputting 6mA,its got a chance.
Keep us informed Al and good luck.Regards jonny.
synchro1
@Gadgetmall-The lutec generator reports a nearly identical COP of over 5. They fire the magnet rotor pulse at the fulcrum point and switch the pulse coil to an output coil after 20% of the cleat shaped magnet rotor passes, by commutator. I believe your snake egg version can be explained well by using their operating theory.
gadgetmall
Quote from: synchro1 on July 04, 2009, 05:40:50 PM
My Test is Done .I am Happy to say its a self runner With Caps . Ultra caps . It has not Dropped nor gained a tenth of a volt since i started this test . 4. 32 is where she stays . and with a battery it indeed does see a charge . I think with a smaller super cap it would charge faster . I believe its charging but the ultra cap is like a dead short to a charger so its going to take along time to see a 10th of a volt increase . My Next little venturse with this one is encase it's electronics and build a capture circuit for the the relay coil like jonny did and then proceed with a satellite coil and try to increase the amount of charge to the ultra caps . . Such a Simple Circuit . Just winding the coil different and a rectifier sk3606 is the only changes i made .. Problem is all the magnets are different in there magnetization somehow and one wobble spins . the other don't do nothing on this coil design . . .l8r Guys . It can be done as i have again proved it to myself and that all that counts . I think its replication with the right magnet . The one i am using i got years ago when they first came out . I have no idea why its magnetized different . I'll get some magnetic viewer film and see if i can tell  later on . I'm curious .
PS . I got me a Digital Storage Scope cumming 200 mzh hatichi . More Fun ! i stole it with a sniper on ebay for 89 shipping included .
Gadget
PYRODIN123321
Peace.
