jacob
Quote from: giantkiller on October 01, 2006, 11:14:10 AM
The next step has definately taken place. It consists of haves and have nots. Those that have done and those have not.
A line has been drawn in the sand and 'Let those without Toroids cast the first stone'.
The most pertinent so far:
Tao release a diagram depicting the coil layouts.
Marcos has done an experiment that produced kicks from 2 frequencies. Great coil, guy!
CTGlabs now has done two experiments the produce sound. Has done an extreme amount of work!
CTGlabs has a biphase controller that is out of phase by 90 degrees.
giantkiller has 2 coils. It's me so I won't ponticate vainly.
giantkiller has a biphase controller that phase shifts harmonically by frequency and direction.
JDo300 built a coil. Another great step into producing something!
Otto built a coil but his image links did show on the post. Please put a pix in your avatar here?
And alot of postings about phased overlapping fields, kicks.
Also alot of flies in the ointment...
If I missed anybody, I apologize.
Hey, just wanted to help here. But I see that my contribution generates more scepticism than enthusiasm. Even antipathy it seems. Why that is, I have no idea. But I guess I will stay silent from now on. I'll still follow your work however because I am curious to know how long some of you can keep pushing away the evidence. Those who want to build a WORKING TPU will sooner or later have to reconsider.
I see all sorts of thing flying by. Some are even playing with concepts they don't understand. But the important thing is to ask: how does it fit in with what I have seen so far. And all theories about intricate methods to produce kicks that I have seen so far are:
1. Extremely vague
2. Don't fit with the notion of a passive device with no battery.
I am also an admirer of Nikola Tesla. He was a great genius! But all of you who seek answers to the TPU from his work should start by reading what is related to the TPU. In other words, READ what SM said about what in Tesla's work apply directly to the device. For instance:
Then he continued his experiments and found that as a thunderstorm moved closer the magnetometers would register larger and larger fluctuations until they were off the scale and useless.
He was fascinated and consumed by this. He acquired better magnetometers and his research found that you could tune the magnetometers to certain specific frequencies and tap directly into large magnetic waves. When I say large, I am referring to huge. That was useable power.
You have to read stuff like that. It says "tune... and tap directly". All of you should know how a tuner works I guess. Strangely, it seems easier to make things more complicated than to simplify them.
You also have to read stuff like this:
Let us say that you have a magnetic field perhaps it is only a small permanent magnet. Now, you have a single copper wire twelve inches long. If you move the magnet across the surface of the wire from left to right at a certain speed you create an electron flow which is DC and it has a power potential based on how strong the field is and how fast the magnet if moved. So, if you increase the size of the magnet or the speed it moves you create a larger flow of electrons, larger as in higher voltage or more currant.
Everyone tells us that the earth's magnetic field is measured as being too insignificant to generate any useable power, that is not so.
Let me give you something to think about...  If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short. OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power available.  If we put it into a perspective of power per inch it may be easier to understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch. If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire. Understand that I am trying to convey a principal that you can understand for use in the future.
Anyone who read those paragraphs and can't figure out the direction of the magnetic field related to the collector windings should read again... and again... and again.
In my first post, I said that if the current trend that seemed to develop keep on going forward, a working TPU could be build before the end of the year. Initially, I wanted to say "before the end of the month", but just decided to lower the objective not to frighten anyone. Well I must rephrase this: if the current trend continues and the evidence continues to be pushed aside, no TPU will ever be built.
Anyway, I was about to disclose my strategy for finding the frequencies needed. But hey, this may not be the proper time or even the proper place to do so.
God Bless!
Jacob
supersam
JACOB,
don't just run away because someone questions you idea!  trust me it will happen in this thread. that doesn't mean that your idea's are not being considered.  think of it as a learning experience.  trust me i have already done the shuttinup, shuttinup theory.  it only means that the forum doesn't have yoour input for that time.  trust me there is something you can add!!
lol
sam
giantkiller
Jacob,
You're a genius! You just exposed a very old electronics trick by mentioning that the TPUs worked without a power source or battery. If those labels are interpreted in the common everyday terms then that is true. Prestidigtation. But we used to charge up caps and then discharge them later on. So when SM throws a switch, why? we never see anytime before or the true runtime of any of the 'self-powered' devices. It is only reported. We actually never have proof?
And by all means if you have an idea but don't make it physically, draw it in paint and post it! Your ideas never put down die with you. I started documenting here after I started diatribing. Later I found that 'MY' ideas were resurfacing as other people writings. I thought plagerism bigtime. Not so. So I then started searching by topic and then 'other users' to see if 'I' was a 'johnny come lately'. In some instances yes, I was and still am. But I found out how the Overunity search engine doesn't work as well as any of us need it. This thread implementation does not have a true 'Repository' function, so things get lost. Too much webbing. That is why I mentioned the 'print to offline search' method. It has helped me greatly. In one of my first posts here I hailed the power of knowledge contained herein. I also requested more avatars of built devices. Notice I said built, not completed or perfect. It was like a call to arms and boom! More avatars of things done. Hey I don't walk on water half the time so my designs are always in limbo. It is called Unit testing and verification. Also SM said that 'There is no power source in these devices that could produce this kind of output. No shit!. That is a semantical play on words. Social engineering in it's final hour. One could put a n-cell nicad through a buck-boost circuit to up the power. When the cap charges it ceases drawing power and waits, excluding the leakage which is minimal. Then SM throws a switch, viola, things work. I mean look at the info trail. SM talks through an interpreter. the interpretor relays that to a group. Someone else in the group claims to figure it out but again is in the 'Closed club' and won't release info. That is just enough info to cause the pontificators and diatribers to theorize uselessly. While the doers have to scrap and claw in the darkness. This is the old 'All knowing, all seeing' eye in Lord of the rings concept. It has been overplayed throughout history. Who are the heros down through history that topple the false kingdoms. My abacus doesn't have enough beads. Joan of Arc, Martin Luther, Martin Luther King, Constantine, Davinci, Copernicus, Kepler, Lincoln, Jesus Christ, Braveheart, Karen Silkwood, need a clue? Engineers work on the premise that the answer can be found and that there are no failures.
Everybodies post have value. No I am not justifying my previous comments. But every so often I gotta light a fire under some butts. A number of posters have gotten bit here by what they say. Hey, I live for the fight. Because that is what makes the truth stand out. Nobody is wrong, It's all good.
Now I gotta get back to my controller building. Damn, that ticking clock is up my hide. Where's that monkey. I wanna shoot something! I bet some of you out there think I'm crazy? When the toroids sqeal, we'll see.
Take care, all.
dutchy1966
Quote from: tao on October 01, 2006, 02:13:15 AM
I will be writing my COMPLETE radiant energy theory, soon.....The way I REALLY think SM's devices work.
Hell, here is a sampler of the theory...(mind you, I am refining this..........)
Here are some terms, defined:
The segmented control coils around EACH of the 3 horizontal collector coils I shall refer to as the 'KICK coils'.
The 3 horizontal collector coils/wire of multistranded copper I will refer to as the 'collectors'.
The coil that surrounds all the other coils and spans the entire device I shall refer to as the 'feedback coil'.
Basically, there is a very sharp DC impulse applied to the KICK coils. This produces THREE THINGS, a B field that is parallel to the collectors, a B field that is contained IN the feedback coil, AND a 'radiant energy' 'apparent electron manifestation' on the collector coils(the more copper the more collected).
More later.................
Tao,
Going by the messages you received from SM, this should be the way to go. SM confirmed the use of radiant energy in them directly. None of the other theories takes that in account. Looking forward to your complete theory....
regards
Dutchy
giantkiller
And another thing!...
In the last 125 post pages of the last 30 days, I have seen more posters, design ideas, designs, schematics, circuits, toriods, experiments, test results, qualified, quantified true findings and reports that at all other times in this thread!
Numerous posters have stated 'We are close!'. No how do ya think that happened?
We are a virtual team. There cannot be a single individual doing this. If so, they will be found and disappeared! We are results driven.
