0 Members and 17 Guests are viewing this topic.
mikestocks2006
Ok I have a very simple question.
Let's take a closed end toroid e.g. 1000 turns 10 cm radius with a base harmonic for 3.5 MHz
Mark the turn at 12 o'clock as 0
and let's say the turn at 3:00 o'clock as 250 (going clock wise)
Next splice a wire on the 0 turn and a wire at the 250 turn
Next apply a jolt of potential to those 2 wires
Do we have 2 sets of currents going through the toroid?
One current from turn 0 to turn 250 clock wise ( through consecutive  turns 0, 1,2, ? 248,249,250 for a total of 250 turns and ? of the toroid)?
The other current from turn 0 to turn 250 counter clock wise (through consecutive  turns 0, 999, 998,?252,251,250 for a total of 750 turns or  the other ? of the toroid)?
Do we have 2 standing waves rushing through the toroid at opposite rotations at different frequencies and effectively amplifying each other when the amplitudes are in sync?
Shouldn?t there be splice location where max amplification at max freq results?
Possibly at exact opposites?, or some harmonic multiple divisor of 1000 (in the example above 1000 turns were used)
I keep thinking closed toroid since in that video the simplest design about 5" dia (the one he placed on the glass table) there seemed to be no outside power sources driving the toroid
Or maybe use a pm to kick start the proccess intead of an outside VA source.
Any insights will be appreciated. Thx
Quote from: ctglabs on October 08, 2006, 03:56:23 PM
Hi Stefan,
I am a member of ou-builders, but I dont think there is anything about it there, although there is some of Grahams previous posts in a text file on there which is quite long.
Yes, but it is already a few years back.
The Yahoogroups also has not a good search engine,
so it is hard to search in these archives...
So, to place two signals both in the primary at once 180d out so they cancel, but see some signals on the secondary?  Sounds interesting, I can try this.
Exactly,
please try it and also try to put 2 transformers in all various series/parallel
configurations.
Somehow the transformers  can act on each other
espcially when you drive them with noise pulses..
Makes me think when SM says "electrons can travel in both directions at once".
Yes, maybe only one component cancels out and the non visible
scalar component adds up....
Graham and me exchanged a few emails during this time,
where he claimed, he could convert the scalar energy back
into electrical energy in a special crystal setup,
where 2 scalar waves did interfere and he was able to light
a fluorescent or neon lamp or something like this, when I remember correctly,
where the interference area of 2 scalar waves was...
Unfortunately he never did publish the real setup and I could
only guess, what he really did do...
But he said, he used ONE transformer, where he drove both
normal 12 Volts output coils 180 degrees out of phase probably
with strong pulses and at one of the core then came also this scalar wave
out, which he could also feel with his hands...
He said, when I remember right, that he also never had
totally canceled output at the 240 Volts coil, which he used
as his secondary.
He might have also shorted it out, so that the scalar wave
was stronger from the core.
He might have also modified the transformer core,
so that he might have removed one iron leg from it,
so that he could point the open core to distant objects...
Too bad, he did not come over here.
I did send him 3 weeks ago an invitation, when PMI announced
his patent, but so far he seems to be too busy to post over here...
Thanks.
Regards, Stefan.
giantkiller
Hi all,
At the risk of sounding incredibly ignorant: I hope all the tests are with toroids. I am partial to air core so that nothing is in the way of the EM wave returning. But also the expansion to the center would cause the flux lines to squeeze or compress into the center building up force. And of course any change in windings would have to happen around the toroid. Can be expensive.
Is anybody with me on this? Should I go back to my desk and put my head down now?
I got the flu but I must go to Radio shack and get some 100 ohm resistors.
Ouch, I just had a thought: What if the harmonic happened in the center also? That would ripple power outward.
Also, with the kick, bemf. Its' been mentioned but how can it be kept in the circuit to sustain power?
We've always been taught to dump or bypass it. Which if you think about it. This simple fix/flaw is where we are at and it seems to me a whole nother area of hidden electronics. The Tesla side.
Thanks guys. This is enjoyable to follow along. I feel like sh*t. Contact Nite & day is really powerful meds for flu! But i can't afford to miss any postings. This 'Around the world in 24/7' is cool. Somebody is always up working.
giantkiller
giantkiller
@dave,
thanks. For the SMs there can be no saturation. And also with air you get the magnetic waves crossing through the center and through to the other side outside? Seems like that could happen becasue there is no magnetic barrier. The would make one very complex field with flux lines crossing spherically like a 3d spirographic pattern. If the flux lines cross each other at angles wouldn't that generate power?
Thanks for the reply.
