mrd10
Hi Marco,
Shit so one of the wires is disconnected from the smaller blue coil, but when you squeeze the larger coil, it actually picks it up......damn did i get that right?
Rgds,
Dom  ;D
mrd10
This forum rocks, I reckon were closer than we think,  So Marco what you are saying is that if you use wire made with iron and place a magnet near it, it will amplify the signal that your feeding into that coil, but when you do the same with copper wire, the signal gets weaker.
Dom
:D
mrd10
Hi All,
I think I know whats going on now, refer to his first prototype, sm energy coil is an antenna, the coil he has ontop, is like a crystal radio receiver, this gets amplified by the coil segments, which are made from iron wire,:- bailing wire which probably have magnets near em also.
Cheers,
Dom    :D
gn0stik
So it works for one pole only one the iron, and neither pole works on the copper..
gn0stik
Quote from: -[marco]- on October 13, 2006, 10:09:49 AM
Quote from: gn0stik on October 13, 2006, 10:04:46 AM
gnostic hi  :),
no its one coil wrapped with iron and copper wire togheter so you have one turn copper and one turn iron one turn copper and one turn iron and so on.
and it worked only on one end.
i did wrap it because nobody said anything about the control coils could have more then one wire in the segments.
marco
Actually If you look at my diagram it's got bifilar control coils on the first layer. Which connect two in series, one in parallel, and creates two resonant LC tank ciruits(not pictured), which are fed by the control circuitry(not pictured), which is fed by the toroids.
However after Mannix's last post, I'm not sure if this is the way to go.. That one really threw me for a loop. Now, it wasn't directly from SM, but mannix does have more contact with him than anyone else. I just wish he posted the results of his tests, so we don't have to sit here reinventing the wheel all the time... I guess that's what we're here for though. Problem with my setup is that it's set up for counter-rotating magnetic fields. However, it could be set up so that both tanks are fed simultaneously, creating the pump, or sqeezing action, the hose (collector)requires.
I'll re-do it to reflect that ;)
