mikestocks2006
Hi argona369,
Will it still retain the "charge" if it's flipped upside down?
Going back to the SM flipping the torroid,
The SM flipping upside down (to shut it off?) is pretty interesting.
After reading posts/pics for e.g tao and others, and translating to mechanical model, it appears to be like a ratcheting system, where in one direction the DC pulse created by the resonant unidirectional wave (geopulse at 7.8Hz?) is ratcheting up the energy into the load. But if it's flipped it works against the ratchet so no output.
Hmm,
if you really can show an EMF pulse after 1 hour in the primary,
that is indeed mysterious,
if you just open the secondary winding !
Are you sure you did nothing else,
like moving the transformer or changing anything else ?
After one hour all the currents should have long gone
to zero due to all the resistance losses...
Okay, you might still have a remanenz fluxdensitry inside
the iron core, but that is not affected, if you just open
the winding !
Hmm, strange effect !
Yes, please try to turn the transformer around by 180 degrees
BEFORE you open the secondary coil and see, if it will
inside the primary again get an EMF voltage pulse.
How big is the EMF voltage pulse ?
Just a few millivolts or more ?
How long does it last ?
Many thanks.
Regards, Stefan.
