scotty1
you can see the patent here.....I had no Earth wires connected though...gotta get around to that.
http://www.tfcbooks.com/patents/transform.htm
I just used a 12v 800ma dc transformer to test with....
fcpeace17
Hi Kosh,
well done your experiment.
How high in amplitude are the pulses in the blue coil ?
Just a few millivolts or in the Volts region ?
Why do you get multiple spikes ?
Is this the Mark effect?
Maybe you need some more windings in
the input coils ? Otherwise you waste too much
input energy, cause the resistance is too low !
Good luck !
Regards, Stefan.
Dingus Mungus
Quote from: fcpeace17 on October 20, 2006, 09:27:47 PM
Quote from: Dingus Mungus on October 20, 2006, 08:40:34 PM
Hey all!
Just been doing some independent reseach lately and came across something I think may help you in your quest for messuring anomylous "kicks" of increasing amplitude. I was reading on J.L. Naudins site about D.L. Chungs discovery of "negitive resistance" and its incorporation in to a "negative resistance oscilator". I immediately thought of this thread, and the possiblity that Chungs device may play a key role in creating and maintaining the input frequencies.
If any of the current developers have the time and budget to replicate a NRO, I believe it will unlock many new doors in the project, and possibly establish a working theory for the input frequencies.
Good work and good luck to all!
You all restore my faith in humanity. ;D
What exactly is an NRO, what is it an acronym for?
also, for IMNADJA "The weak 5k AC component found on the output is due to superimposition of the magnetic field in the top and bottom coils on the middle coils, but it isn't anywhere near as strong as the magnetic field set up when the radiant hits that middle collector" are you saying that the 5k is a beat frequency of the top and bottom coils imposed on the middle coil? Evan
Chung's Negative Resistance experiments
http://jlnlabs.imars.com/cnr/
Oscillation amplitude and energy grow exponentially with time...
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/RadCom/part5/page1.html
I've found this device today, and the phrase "like a fire that feeds its self" popped in to my head. Mr Mark had told that to Mannix once, and this device appeared to fit the discription very well. If one could dump the excess amperage in cycles timed with the resonance of the combined frequencies, I believe it would be a self running overunity device. I only know the very basics about working with electronic components, but I had a gut feeling that this was an important piece of the puzzle in some way...
Quote from: ctglabs on October 21, 2006, 03:59:34 AM
Quote from: hartiberlin on October 21, 2006, 01:52:21 AM
Stephan,
You can see from the pic that that CH1 is 200mV/div.
Dave.
Ahh, I see, so the peek to peek is already about 800 Millivolts !
Not bad for such small windings input coils !
If you will wind up some more turns for the input coils
and also with much more smaller diameter,
that would probably raise much the output power !
Also don?t drill the input coils at the end , as you can get confused,
where to put the right polarity input pulses.
All input coils must have the same turning direction also.
It would probably be okay, to have just only 4 input coils.
Regards, Stefan.
