gn0stik
Quote from: imnadja on October 26, 2006, 12:40:44 PM
Dom, you cannot tune to a magnetic field, because it is just that, only a field with no electric component. You can only tune into an EM field, as in radio waves.  A magnetic field has no oscillation.
this is true, there is no 7.8 hz magnetic field
There are a few other misconceptions going on here as well. The Shuman resonance is a mechanical resonance, not an electromagnetic resonance, not a radio wave.  It is the literal physical vibration of the planet at 7.8 hertz, just like the physical ringing of a bell, and through coupling with the atmosphere, a sound pressure wave at the same frequency.
There is no RF wave at this frequency, at least not for our purposes here, there is extremely little energy in an RF wave of this length anyway, certainly not enough to even begin to power our circuit and be amplified through some self powering mechinism.
This is completely wrong. The 7.8hz Schumann is in FACT an ELF EM frequency that travels through the space between the earth's surface and the ionisphere, which acts as a waveguide and resonant cavity. The earth is not the "bell" as you suggest, but the atmosphere is. However, it is excited, or 'rung', by lightning.
There are in fact schumann receivers that you can build.. see www.vlf.it for the plans, I think.
You are correct however, it doesn't carry much power. But it might be enough to start an oscillation with the right setup.
Other things to consider:
What do we know from Tesla about releasing the radiant energy?  One, it takes a DC pulse, AC won't work, so any energy derivied from RF or AC must be rectified to DC.
Two, that the DC pulse must be repeated very, very fast in order to produce radiant energy.  If I recall correctly this must be on the order of 200 MHz just to begin producing radiant which would be hot radiant like in SM's device, and over 400 MHz to produce cold radiant as in Gray's device.
This is all good. But the next part....
Three, in order to produce Tesla's radiant you need a very high voltage, somewhere between 500,000 and a million volts.
So, if you are trying to produce a radiant with anything less than the above parameters, it ain't going to happen.
The most noticeable effects of radiant are produced at the high voltages that Tesla experimented with, yes, however, there is no evidence that the effect is completely gone at lower voltages. In fact there is more evidence, albeit circumstancial, that says that it does exist at lower voltages. The experiments of Gray for example did not use voltages anywhere near what Tesla used, yet there were strong indications of radiant energy involved. Neither did the devices of TH Moray.
Just some things to think about.
Yours,
Don
raburgeson
Well I finally got a math handle on Torroids, the last mistake fixed was the dumbest as you wrap 25 wraps on a collecter core , measure the capacitance of it and divide by 25, (capacitance to low to measure 1 wrap) this is wrong because there are 24 spaces between 25 wraps. Anyway Steven was right I do not know the correct way to build a TPU yet and at that point I was still unready. Now I think I am ready to reread and build. I would like to draw your attention to the picture of the TPU with the cutaway. The cores control windings are for all purposes and effects symetric. The top core and the bottom core are in the exact same relationship with the outer shell or global windings. It would make sense then that these are in either series or parallel with each other. Both will react the same to the outermost windings and the center core. Steven said not interleaved. The center core has the same relationship with both the other 2 cores and the outer windings. One possibility I will try is the top and bottom coils are to be in parallel. I have not yet seen a way to series these to uninterlayed. I feel many posts are lost as I have found references by way of quotes that point to posts that do not exist. Also I have not been able to find anything about bifiler windings, were did that idea come from?
