sparkman
When water goes down the drain it spins. It does not spin sitting in a pan. Large electrostatic forces are developed between the laminar flow as they slip past each other. This interacts with the earths magnetic field, thus winding up.  If the water is pumped back in to the top the spin will be limited by the frictional loss of the water. In the equivalent magnetic device there is far less friction and it can wind up to considerable speed. Radial rotation is required to get the axial rotation you are looking for.
giantkiller
This is based on the Tesla 390721 patent.
We are going to used the same words that SM and everybody has been using, ok?
Focus on the transformer. Through this thread everybody has looked dead at it some time or another. But based upon the SM descriptions most everybody has taken those words into their own experiences and knowedge and has tried to apply them. Mannix has said, and others, that the answer is right in our noses. So here we go.
Back to the transformer...
@MRD,
your wiring pic is the output. Try mapping the input side. It sure is different.
@everybody, the input is what is odd. I posted a flash file showing what the fields look like when rotating. This is not theory. Look at this again.
When the term 'out of phase' is used it can point to the two pairs of coils being driven against each other. Because when we think about rotating fields it has been shown here we all think they going the same way.
When the term 'Counter rotating' is used this can be left to interpretaion. The coils them selves are driven backward every 180d. My flash script shows that.
When the term 'Two frequencies' is used it can mean a different thing. Look at the transformer again. There are 2 pairs. Each being driven at different times. A good explanation would be two frequencies, whether the same or not. A simple explanation about two seperate drives. Looking at from the coil side, a good description to the uneducated would be just that. Example, We have a guy in business clothes that grabs two hot wires and injures himself. I would have stuck a piece of wire across them if I thought I was witnessing a fraud or something incredable. We now already have our first victim. And the horse is not even out of the barn yet. Thanks Mannix.
When we look at the 4 coils we all jumped on and went down the path of firing these in sequence. The Telsa transformer is being fired in pairs 180d out, forward and backward, forward and backward, forward and backward.
Yes. Since this whole thread has been by obscurity, then try listening to the semantics instead of the technical. It paints a whole different picture. If you look at my avatar, you can see all those the posts to connect to. IT consists of 4 segment of bifilar pairs, all equal turns on an iron core. This platform can be connected by either technical instructions or reconnected/jumpered to fit any type of semantical implication. My controller has the same attributes. I can jump to the next reconfiguration at a moments notice. Nothing exotic, just flexible like any experimentation test bed is. And in following these posts it is still hard to keep up. ;)
In the Tesl 390721 patent, he mentions the output at Item 60 and mentions the motor also. He does mention the odd transformer at item 80. But only as output. Did I miss something here? As I said in my previous post, this is strange. Is he hiding something here? In patents, only pertainent items are entered. Anything in diagrams has to be fully explained. You just don't stick things in the patent documents without acknowledging them with some kind of cross reference. That is mandatory. So what is up with the transformer. The small reference at item 80 doesn't pay hommage to how that thing is fired. Especially with driving power of what the patent is stated to be about. I hope I am missing something.
@Mannix,
Your avatar shows a guy on a motorcycle tied to a hanglider or parawing with a helmet on. The helmet will do him no good. If he falls on his head he breaks his neck. If he is lucky to land upright (been there done that) he has 150lbs of metal splitting his crouch in two directions. There is one law of nature that is never advertised to the uninitiated hangglider watcher. That is 'Everything above 22 feet is concrete'. Do I know you from somewhere? Or are you posting to see who can see beyond the boundaries here? ;)
--giantkiller. Do I need to put on my xray goggles? :D
giantkiller
Oops. Forgot the major part.
The 390721 patent has square wave AC + and - voltage from the commutators. BEMF from what cycle. ;)
--giankiller. Post lest we roast.
mkt3920
A tube "powers" up and powers down....the TPU "winds" up and winds down.
Kent
mikestocks2006
Catching up reading last posts.
Two quick comments
Safety.
Imagine for a second, the first human who discovered the ?gift? of  how to start a fire not using the gift and not telling others, fearing arson or people getting burned by misuse?. Where will we be today. Still in caves?
Gravity.
What is really the nature of gravity? We see the ?effects? of ?a phenomenon? we label gravity. But lets assume that if mass is high frequency energy slown down in ?our? reality, and an electromagnetic field  is ?energy? then, it may not be far fetched that a proper configuration of an energy field can produce gravity and thus a gyroscopic effect as we understand it today.
And how do we know the "particles" and ?sub particles have mass??,Doesn't a spinning field produce similar results? We only think we measure the effects and infer as to the nature of the source?
Someone said it before. It?s all about frequencies.
Great work folks. We are witnessing history in the making.
