gn0stik
Quote from: JackFrost on November 01, 2006, 07:47:09 PM
Here's some food for thought:
I found an old reference to the SM device that mentioned that "resonance is established using the
mechanical (Lorentz) forces developed in the coil".
Read up on Lorentz forces (as i recall this is what causes transformers to "hum" - i.e. a mechanical force) and then "Laplace force" and found this:
http://science-on-stage.web.cern.ch/science-on-stage/Webcatalog/Greece/greece7.htm
What if the device itself is resonating - flexing in and out?  Tuning would be a function of the coil mass, coil wire length, and cross-sectional aspect ratio (is it really round?).
Whenever the coil vibrates - it interacts with the magnetic field of the magnet.  Coil output would be based on the rate of change and amount of flux.  Might be preety sweet if the frequency is high enough...
Any comments?
Where is this old reference located?
gn0stik
Quote from: ctglabs on November 01, 2006, 02:46:31 PM
Rob,
Waves adding and mannix diagram are different things by the way.  The normal waves must be in 100% electrical and spacial phase to add.  Mannix drawing was more about this squeezing effect.
Dave.
Yes but SM nevertheless talked about the interesting things about xformers out of phase. Not in phase... or connected in reverse of one another.
QuoteThat combines with the 5 volt 60 Hz in the coil of the htr transformer and generally amounts to nothing. In fact the power of the 5 volt transformer amounts to nothing. It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another. Then you can measure all kinds of things going on. You can generate all kinds of hash and multiple frequencies, and I do mean all kinds. What I measured during this process was very interesting. All these frequencies occasionally met at the same time with a much larger kick at the output
gn0stik
I have to say this by the way:
I'm pretty well friggin disgusted with how this has gone. SM posts something via Mannix (WHICH WE ALL SUSPECTED BY THE WAY, PEOPLE), and we completely lose it? Chase Mannix away, and make him delete all of his posts? Luckily I have most of them saved, all the important stuff anyway.
SM came out and let it be known that he wasn't positive that it was from the EM field of the earth. BIG DEAL! It meant nothing to the development paths we were taking. It doesn't change the fact that kicks are universally attributed to the interaction with ethe earth's field. It doesn't change the fact that there's a rotational magnetic field which causes the squeezing, it doesn't change JACK SHIT about what we know about the device thus far!! NOTHING!! In fact it freed us from the logical constraints we were working under!!! We should have been thankful.
It doesn't change how we develop the kicks, or the experimenting process of discovering kicks. It doesn't change anything about it. In fact, many of us have surmised that there was a gravitational component in addition to the magnetic component, which caused the gyroscopic forces, the true cause.
When he said that the device drew energy from the earth's magnetic field, it WAS the most logical conclusion.... AND STILL IS!! If kicks are overunity, and they are attributed to interaction with the earth's EM field, it IS the most logical conclusion...
Does that mean that's all that's going on? NO WAY! Hendershott's device worked similarly and had gravitational components. T.T. Browns work dealt heavily with EM stuff, and there was a gravitational component to that as well.
Combining frequencies cause serious gravitational anomalies in John Hutchison's work...
I don't see why the HELL this was so shocking..
How fragile we are. How incredibly fragile. HE was RIGHT when he said that there was no way of confirming it at the time.. and that it was unimportant. He knew how it worked, and how to build it, and tune it. And for all we know, he was RIGHT!!
Thank you for that last post Mannix/SM, now let me squeal and bitch about leading us on like a highschool cheerleader. Those of us with equipment, and the ability to test should be exstatic that he was even still coming here. Now, when I get my equipment he will be gone.
But I will do what I can with what I have, and no hope of getting any more.... You know there was more, don't you? I mean, you guys knew that wasn't all of it that Mannix had right?
There is more in Heaven and earth then we shall ever know.
gn0stik.
gn0stik
Quote from: supersam on November 01, 2006, 10:30:32 PM
hey rich,
one more time three in parallel, two in series, "one in parallel".
lol
sam
Thanks sam, I needed that   ::), but it's not quite that simple.
EMdevices
