0 Members and 17 Guests are viewing this topic.
joe dirt
to those who made the TPU vids, I would like to thankyou for making me aware
  that such a thing as this TPU can be a reality.
Dirt
giantkiller
devilzangel
Bruce_TPU
Everyone will enjoy this if you have not seen it, especially Marcos and Otto.
Original
http://www.magneticenergy.org.uk/Mini%20Romag%20Generator/Mini%20Romag%20Generator.htm
Reprint
Some interesting things that could also pertain to the TPU.
P.S.  Did you know that 245 KHz is the frequency in the Ionesphere that AC joins itself to lightning?
P.S.S.  Did you know that 35.705 KHZ is the frequency in the Ionesphere for the forming of the Polaris lights?
Hmmm....coincidence?  I think not.  No wonder it took them "years" to find the right frequencies.  Perhaps we should use these, their harmonic and intermodulation.
Cheers,
Bruce   ;)
Pics of my new coil tomorrow sometime on my thread!
