Thedane
Nice box Jason,
Where did you put the fuses?
- I can't seem to be able to spot them.  (A transformer THAT big  ;D can do pretty nasty things when shorted) ???
On a different note, Bedini seems to think the key to radiant energy lies in PWM - I'm still making up my mind  :-\
innovation_station
@jason it makes me happy to see you have switched to tubes to find the answers may you have the  best of luck i dont think it will take you verry long to compleat this project using tubes ;)
ist
edit: just a thought after reading the below
what hapins beond the speed of light   hummmmmm
time travel of course
i think the tpu is just the verry bengining to the end!!!!
dutchy1966
Hi Jason
What about this for a start?
If an EM field is somehow rotated extremely fast, shouldn't all matter be repelled from its center? -kgo.
How fast do you want it rotated? It's fairly simple to construct a system to produce rotating EM waves at whatever rotational velocity you wish by feeding a pair of broadside dipole arrays with quatrature phased waves. It is quite simple to construct a system that would have a rotational velocity of C within the uniform field area. It might also be fairly easy to do this with a Hemholtz coil arangement as well, but the broadside array will be much easier to do at easily engineerable frequencies. Some really interesting paradoxes come about when the rotational frequency is high enough so that the rotational velocity exceeds C within the uniform field area of the arrays or within the hemholtz coils.
Robert Shannon
What effect would there be at the boundry where the rotational velocity reached, and then exceeded the speed of light? How could the magnetic field even propogate to the center of the antenna structure if it would have to move faster than light to reach that space? If hemholtz coils were used instead of loops, the magnetic field strength would be uniform inside the structure, how could the field strenght be uniform if there is not sufficient time for the field to propogate through the space inside the structure itself? Could such an effect actually generate a wormhole like phenomena, at energy levels far below that of neutron stars and such? As the causal mechanism, the magnetic field, is in roation, would this describe a traversable worm hole as has been postulated in relationship to rotating black holes?
Grumpy
Quote from: Jdo300 on August 15, 2007, 08:59:15 AM
I have focused my attention on experiments involving high-speed rotating magnetic fields at resonance.
Might try rotating the "potential" rather than the field.  It is the potential that creates the field in the first place.
        -Frank Edwards
innovation_station
is the rotation not set up by the way it is wound and wired that is what i thought give it a pluse and it spins give it 2 pluses oppsite and it cancles the flux give it 2 freqs that smash togather in the wire and it makes the 3rd no?
is
