how the major systems on a pleiadian saucer, work.
Started by nitinnun, April 01, 2009, 10:36:07 PM
Atlastired
Harmonics, using the right frequency waves do have the particularities to create a vacuum path.
Harmonics were used in the 60's, the Philadelphia experiment and now we have someone who burns sea water with it.
But because it doesnt goes with the "Jewish Fraud" of Einstein we dont talk about it.
But you didnt mention it, you are sticking with ionizing rays that will wait for the ionizing matter to bond slowly to the surrounding media...
gravityblock
Here's a few of the methods used to meet the energy requirements of the spacecraft.  It can be obtained by turning hydrogen into helium at low temperature and bombarding deuterium with heavier mesons, releasing a fabulous amount of energy, or by using ultra rays in an acid solution saturated with helium nuclei. The latter process is the most usual.
Here's how the transformation of ultra rays into usable energy takes place.  If you allow radioactivity to pass through a magnetic field you will get alpha, beta and gamma rays. The first are helium nuclei, the second are electrons and the third are gamma rays, which are similar to ultra rays in their electromagnetic content. These three components of radioactivity are related.
The ultra rays, or gamma rays, on passing close to helium nuclei, bring about a deformation of space and give birth to electrons until their wave energy is expended. Thus, when gamma rays pass through an acid solution saturated with helium nuclei, the newly created electrons gyrate around the nuclei, but the acid prevents them from joining up with the nuclei, and they are collected on plates at the bottom of the apparatus. This provides an inexhaustible supply of energy which requires nothing more than a little acid solution and some helium nuclei.
There are, however, other means. Something might go wrong with the apparatus used for transforming hydrogen into helium and the gamma ray collecting apparatus. If this should happen then they turn to solar energy and will pass it through a tube of coal gas. This gas, with a suitable catalyst, unites with water, turning it into formaldehyde. This product is then oxidized, producing coal-gas and water again.
In this second process solar energy is turned into usable electric current, which is quite sufficient to meet there immediate requirements. The laws of inertia provide them with the necessary acceleration to reach the planet that is their objective.
Most of the flying saucers, but not all, have a hollow tube running through their center. Inside this there is an air turbine. If some 300,000 kg. of pressure is sufficient to move a saucer of 20 m. in diameter, and the available pressure exceeds 3 million kg., there is a considerable margin of surplus energy. The air pressing against one side of the saucer rushes through the vent into the area of the vacuum and creates a strong current that actuates the blades of the turbine.
In a "tunnel" of air 4 meter in diameter, pressure on the turbine blades would be equal to 130 tons, that is, the pressure of a jet of water of 1 sq. meter falling from 130 m. The current of air thus produced would be sufficient to suck a man into it from 100 yd. away. If a saucer with its turbine working were to pass over a tree, the movement of the air currents would strip off its branches.  The energy thus obtained would be sufficient to keep a dozen factories going.
This is the way in which the inhabitants of other planets generate the electrical energy they require without using waterfalls, which are preserved for their natural beauty.  The air that goes in one side rushes into the vacuum and is there immediately ionized and absorbed by the atmosphere.
Now, the Earth develops a surface speed of 1,040 m.p.h., but no one feels it move. This means to say that if we continued to rise in relation to a point on the Earth's surface we should be increasing our speed, but would have no sensation of acceleration. On reaching a height of 250,000 miles from the Earth's surface we should, without any other effort than that of going upwards, reach a speed of 66,000 m.p.h., which is equal to the speed of revolution of the planet in space. We neither see nor feel the speed we have reached as we have no point of reference; but if there were a stationary observer outside the etheric envelope, he would see us moving at a terrific angular velocity.
Having reached this speed we would try to escape from the etheric covering, falling into the vacuum. Due to the tendency of moving bodies to move in a straight line, we would leave the etheric envelope at a point at which the saucer, by following a straight line, would reach the planet they wanted to get to. The procedure would of course, be different if they were using the "electric fluid" of the planet as their means of propulsion.
In practice the minimum escape velocity they use is 125,000 m.p.h., of which 66,000 are supplied by the Earth and the difference by the speed developed by the saucer within the atmosphere. Sometimes they use even higher speeds, which to us would seem incredible.
With a high escape velocity they only require fuel or other sources of energy in small quantities for use within the saucer.  They can completely disconnect the Crookes and Geissler tubes which bring about the atmospheric disturbance because they no longer have a need for them once they have escape from a planet.
There are also other methods, such as producing anti-matter or positrons.
GB
gravityblock
Quote from: gauschor on September 27, 2010, 08:30:10 AM
I guess one needs a very strong electrostatic generator producing millions of volts potential difference to research in this area.
On a saucer, the voltage and current are very high indeed.  A really tiny craft used for research with no payload to carry, then very little current would be needed.  We wouldn't need the millions of volts for a tiny proof of concept model, but still would need a few hundred thousand volts at least.
GB
Atlastired
First of all the Nazis worked on anti-gravitation back in the 1940's so they were able to use the manufacturing technique and technologies of the time.
So we took over and apply those techniques to build a working UFO in the 60's so look instead at magnetism and magnetic field manipulation.
Your design wont be able to structurly resist to the pressure you described, facing a wall of air at 1 atmosphere at the speed you describes will torch the UFO, the vacuum if any, is applied all around the UFO, not processing it inside the structure...
The technologies were developped by the Nazis, so dont get all paranoid like Rabbi Billy Meier
They are still keeping us blind from real science with Newton 1650's and "Jewish fraud" Einstein
Thats why we are still using explosion to get traction, we are stuck in the 1800's WW1 was the end of science.
gravityblock
Quote from: Atlastired on September 27, 2010, 12:11:32 PM
The vacuum is not applied all around the UFO.  The vacuum is only produced in the direction of travel.  In order to go straight up, then the vacuum is produced on the top portion of the craft, and the craft will be impelled into the vacuum from the atmospheric pressure underneath.  The craft is not facing a wall of 1 atmospheric pressure, but will be facing a wall of 0 pressure, thus there is no worry for structural damage, fatigue, or being torched.
You have no concept of nothing, and always taking things out of context.  If it's not totally broken down for you at the most basic level, and every aspect of it described to you with the utmost details, then you are totally lost.  I'm still trying to figure out where you come up with the idea of an air compressor, LOL.
GB
