Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
Cherryman
Quote from: AquariuZ on April 08, 2009, 05:27:17 PM
BREAKTHROUGH
I have just realized something.
What if there are moving weights and static weights moving up into position ONE SHOT AT A TIME.
No need for explosive action all the way up, just kinetic transfer..
I´ll try and explain: Remember the little toy where you have 6 steel balls suspended from a wire and you take one, let it fall and the last one on the other side gets shot-putted?
THIS IS IT.
The holes on the side are to stack the weights inside a holding system which is placed just left of the axle. (Pre-start) The placeholder is for 7 dumbbells.
The other nine dumbbells are then loaded at the following positions
13:00 weight number 1 of 16
13:30 weight number 2 of 16
14:00 weight number 3 of 16
14:30 weight number 4 of 16
15:00 weight number 5 of 16
15:30 weight number 6 of 16
16:00 weight number 7 of 16
16:30 weight number 8 of 16
17:00 weight number 9 of 16
Now visualize 7 stacked dumbbells in a holder to the left.
[WEIGHT NUMBER 16 OF 16] <-- TOP OF STACK
[WEIGHT NUMBER 15 OF 16]
[WEIGHT NUMBER 14 OF 16]
[WEIGHT NUMBER 13 OF 16]
[WEIGHT NUMBER 12 OF 16]
[WEIGHT NUMBER 11 OF 16]
[WEIGHT NUMBER 10 OF 16] <-- BOTTOM OF STACK
They are stacked and in direct contact with each other
Weight 10 is just up and to the left of the six o clock socket
Weight 16 is just below and to the left of the twelve o clock position
THIS IS EXACTLY WHERE HE DESCRIBES THE ACTION IN THE FAQ
Let go of the wheel or push it.
the 17:00 weight moves to 18:00, leaves its socket when it encounters the barrier/holder and then makes a direct hard contact with weight number ten, which is on the bottom of the stack. The kinetic energy is transferred all the way to weight number 16 which is on top of the stack and forces weight number 16 into the holding socket at around 12:30.
Weight number 16 becomes weight number one.
I just slapped my forehead, because he did say "Kogelstoten". Shot-put did not mean anything to me but you can compare "Kogelstoten" to a Jeux-de-boules ball violently displacing another ball and taking its place.
Cherryman your 7-9 remark just now removed the cogwebs from my brain, thank you my friend.
This I can indeed make a model of, I am getting excited now.
O, you noticed? (Clicking on WM.EXE)
;D
Hey Aquariuz,
I tried the kenetic energie ting..  Just today... from you're D remark.  But i could not get it to simulate properly.
I started to simulate indeed the little toy, that was already a problem.  Then i tried the same setup in D position, with a wheel but my problem was that there wasn't enough energy, AND the stack will try to move downwards...
So i hope you will found a solution for that!
AquariuZ
Quote from: Cherryman on April 08, 2009, 05:33:07 PM
The stack is held into place by the rotating arms wait and see so I can show you
The point where the balls touch created a powerful kinetic jolt moving just the top weight
Modelling now... Make sure to select "Steel" as your material for the spheres.
Alexioco
Dont know if this helps but I have studied the youtube video (the one without the subtitles) so I could see as much of the wheel as I could, I have drawn out the wheels frame work, you can check it with the video to make sure I havnt got somthing wrong but as far as I can see, it seems right...
On the footage, the is a straight piece of wood the runs diaganol along the wheel, I dont know what thats for, unless its just to support the wheel, so I have left that out for now.
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Cherryman
Quote from: AquariuZ on April 08, 2009, 05:41:28 PM
It sounds good!  Maybe i did something wrong.  I hope you get it!
And steel.. Not sure.. what i used.. i Think default.
I'm curiuos to you're rotating arms.
Hurry!  ;D
