MylowHJ Replication - Discussion
Started by wattsup, April 04, 2009, 08:49:58 PM
jester
Quote from: TinselKoala on May 22, 2009, 07:07:16 AM
I saw a YT video that says that 3 + 3 = 8.
I found this to be completely in line with my theories of integer cloning.
So I tried to  replicate. Here's a page from my lab book.
3 + 3 = 8.
er....
3 + 2 + 1 = 8.
hmm.
1 + 5 + 1 = 8.
Making progress!!
5 + 1 + 1 = 8.
Grr. dammit.
6 + 1 = 8.
5 + 2 = 8.
Let's try a different approach.
9 - 2 = 8.
9 - 3 = 8.
9 - 4 = 8.
9 - 1 = 8 !!! Success!
We need more replicators!!
(coffee spilled here, a blood stain, further data missing--a page torn out...Hmmm.....success, suppression!!!)
reverse one the 3's (mirror image) and put it on top of the other 3 and it can equal 8.
I have not said it yet but that was good work on your video's TK   ;D
Quote from: jester on May 23, 2009, 09:49:34 AM
Trickery! Fake! I see the fishing line you used to rotate that integer through the nth dimension.
You can't fool me, that's not real integer cloning.
;D
(thanks, I'm glad you liked it...)
wattsup
Well call it what you will.
The evidence that video #6 is a fake is extremely slim. This also can't explain when he removed the stator bridge to show the stator close up. When he put it back into place there was not attempt at all to pass a string through the hole. The move of the stator bridge when he showed the stator means if there was string there, it would have been created considerable slack on the string. Again this is not seen and for all intents the video #6 CANNOT BE USED TO CALL THE CHANNEL MAGNET WHEEL A FAKE.
Also why would Mylow provide High Res videos to Sterling on the bar magnets wheel and not on the channel rotor wheel. Most likely because HE WANTED US to discover the bar magnets wheel was a fake.
So, I smell an attempt to subvert our attention away from the channel magnets to the second bar magnet wheel and because of this simple discrepancy, I am still going through with my further tests on Mylows wheel.
As posted by @maw2432, I am also putting the link to empireofmotion's Youtube showing her new wheel.
http://www.youtube.com/watch?v=JBkdgMQj0-4
I am now showing my final build. I to am still waiting for my magnets and will do some preliminaries with neo magnets.
Build spec on my wheel is as follows.
Wheel is 18" by 1/4". My 1/2" disk also on hand for other trials.
Dual ceramic bearings are lodged inside the center shaft.
The base has a 5/8" shaft coming up about 2 inches to pass through both bearings that are distanced inside the shaft.
The top disk is held down with four aluminum bolts. The center hole goes all the way through the center shaft to the bearing chamber.
Now to build my stator bridge. lol
Anyways, just wanted to show that some will still try this.
@queue
If you no longer wish to partake, and if you want to sell some of the magnets, please let me know. I had ordered only bar magnets but will also have to order some channel magnets.
@all
I think we are nearing the time when the main thread will be simply locked since there is no real advancement expected there and these two liners posts are just taking up space and lot's of lines on the recent posts section.
wattsup
Second image added to new post because the "more attachements" feature does not work.
lostcauses10x
wattsup
Looks like a good table.
I must ask what you plan on doing others replicating have not done??
Let use know what happens.
