Picture of my Savonius experiment
Started by joegatt, February 04, 2006, 02:10:59 PM
joegatt
Here's a picture of my test rig of a Savonius windmill.  The rotor is mounted on the axel of a small DC motor.  But this is not the right way to draw power from a Savonius because of the low speed of rotation. In fact the output voltage typically hovered below 1 volt, only reaching 1.5V during unusually strong gusts of wind. The motor needs to be geared up to high speed, or, better still, a custom-wound alternator is used as in the Picoturbine.
Joseph
esaruoho
http://www.instructables.com/id/EVM8ECZA4VEYKVV734/
Build a Savonius Wind Turbine or VAWT to make electricity
from instructables. this should be fun to do - if one has the funds to do it
fleebell
An now you can try one this size for a bit more power ;)
Localjoe
@ all
I made one similar to this, try taking all 4 half sections of can or bottle or whatever you cut and putting them on the same plane, not two on top and two below, you will get much better acceleration with mabey a few mph wind and have constant juice but you need all 4 together on the same horozontal plane  :)
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
