Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
Groundloop
@wattsup,
My drawing is a direct copy from his videos.
@chrisC,
You are correct.
Regards,
Groundloop.
chrisC
Quote from: Groundloop on April 27, 2009, 07:47:34 PM
@wattsup,
@chrisC,
You are correct.
Regards,
Groundloop.
Thanks Groundloop. And I think Tommey is correct. Here's my understanding from the latest 2 videos.
The battery & PWM draws 116ma and I assume a duty cycle of 50% at 12V. This is an average power of 0.116x12x0.5=0.7W.
The unloaded capacitor voltage spiked at 115V but settled at 24V useful voltage and runs the motor at 68ma (assuming it's all DC) giving a power at 1.63W . That's proof of O.U!
Correct me if I am wrong.
cheers
chrisC
powercat
53
Pulse generator, 30% load on bach EMF coil.
http://www.youtube.com/watch?v=GzS7MN_u-54&feature=channel_page
Quote from Tommey
At 30% of pwm pulse at 10khz the output of back EMF is greater then pwm set to a 50% pulse.
At higher amps at 30%, the increase of back emf of current.
cat
Groundloop
@chrisC,
Based on the measurement in his videos, yes, you are correct.
I have modified my test circuit with a hexfet (IRF840) instead of a regular transistor (2N3055).
It seems that I can not loop the output directly back to the input because the internal resistance
of the lead acid battery is so low that it is a short circuit for the captured back emf.
So if we want to do a full looped back test circuit then we will need a impedance match at the output
and to the input.
Regards,
Groundloop.
nievesoliveras
@all
My question is:
Is he using an in circuit PWM ? Or He is using an outside PWM ?
If the PWM is from the outside then there is not OU.
Jesus
