Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
Ergo
I'm back Tommey.
This time I have drawn a test setup proposal.
Using your oscilloscope and series shunt resistors will give you accurate readings.
I really hope you follow my test guideline. It will show us all whats going on here.
peper10
Quote from: Ergo on May 14, 2009, 05:26:39 PM
I'm back Tommey.
If you are so educated,performed it ...
If you are so PROFESSIONAL as you said,you have all the equipement??DIDN`T YOU.
The JOKE is going too far.
If you want to participate in this interesting discovery....Thats fine!!
But don`t make other ridiculous with your presumptions..
You don`t judge someone with the clothes he wear....
I ask you to read this forum for a while,just to see where it goes???
Don`t reply to this message untill you have think about what i said...
Tommey Reed
I see what your testing will show, but first let me say that one tests that gotoluc did on this pulse generator was good enough with everyone, and it prove that I had a big waste of energy.
Everyone jump with joy when his video came out, I am getting the idea that maybe all this talk is wasting my time.
I had to show that capacitor test did'nt hold water when using them as a calculation of OU, in fact if you charge one up and drain it in to another cap you have wasted energy.
I even tried more test today having lightbulbs as to show how much energy was being used and how much energy was being made.
Everyone said I told you so, no OU.
The second lightbulb test showed the opposit at lower pwm rate and higher frequency, and yet nobody commented on that one.
Even the capacitor tests I did did show greater storage when both capacitor where balanced then what a battery charge capacitor could do.
Nobody would comment, and yet when gotoluc did these test everone had to put there two cents in.
I think its time for other to build this and test it them selfs.
I feel my time has been wasted,and yet none of you have really made this simple circut that I gave to all to find your own answers.
I will see what parts I have left to do the higher amp load test again, my bigger mosfet power board blown last time, I was testing the 120v battery pack running the 10kw generator.
Tom.
Tommey Reed
I really don't want us to get out of control, But some things I know very little about. Its seem that everyone has a higher degree then I do. As a high school drop out, I had to go and work to help my family out and buy my own things i needed, because we where poor.
But that my past, as for know I do listen and hear what people say.
Its hard to say OVERUNITY, but every test I have done with no back ground in schooling is showing higher output then input at different testing stage.
I have no problem if I'm wrong, but nobody has really prove it yet.
Not to bash gotoluc, but I did show his calculation was off when using capacitor to disprove the output.
Tom...
hartiberlin
Hi Tommey,
regarding this video:
http://www.youtube.com/watch?v=GoLQFeU4rV4
Hi Tommey,
what is the coil´s DC  resistance of the transformer ?
in the input site you have a series circuit
of the bulb PLUS resistance of the coil,
so the power is parted between the bulb and the coil.
If you put in 1 Watts to the input bulb and 5 Watts into the coil=6 Watts
of total input power and getting 3 Watts out of the output bulb your circuit is still not overunity.
I don´t want to bring you down, but this is the way I have seen it in my earlier experiments with these types of circuits.
You really have to start using your scope for the measurements..Only it can tell you, what is going on...
Keep at it. You will get it !
Good luck !
Regards, Stefan.
P.S. Have not had time to watch the newer videos,will do soon.
