Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
Groundloop
Luc,
Thanks Luc, when I connect my battery to the circuit then the voltage drops 0,5 volt.
The circuit is using very little current from the battery (less than 1 mA) but I can see
from a o-scope shot (measured direct over the battery terminals) that the circuit
uses more power than it gives back to the battery. (O-scope shot attached.)
I'm not able to get any useful information out of the videos. He should put the camera
onto a stand and use better lightning. He should also label his instruments. That is
my humble opinion.
Groundloop.
powercat
amigo
Why does he keep talking about BEMF, like in this video?
http://www.youtube.com/watch?v=wlYKg42_oks
I though he was collecting inductive collapses NOT the BEMF?!
My understanding is that BEMF is opposing the voltage that's creating the EMF in the coil simultaneously while the current is switched ON (like inertia relating to the movement of some mass in space).
He says at 4:25 that when it collapses (the field) "...instead of going back into the battery, we now redirect it upward."
Redirect upward how? The diode there will also prohibit the flow, as it points downwards?!
I assume he uses the Conventional flow of current (positive to negative) and not the Electron flow (negative to positive), as indicated by the arrows on his drawing.
powercat
Here is another new one
Pulse Generator, running power tools 001
http://www.youtube.com/watch?v=_40VRPEINT8&feature=channel_page
Maybe he's going to do live streaming next ;D
cat
chrisC
Quote from: powercat on April 25, 2009, 02:29:07 PM
cat
Thanks Cat for updating his new videos. I have been following Tom's stuff on youTube and this guy is not only sincere but is hands on and no dummy, even though he's not 'university' educated. The numbers on the battery outputs & PWM inputs to the coil outputs driving the capacitor & motor seemed amazing. Even though the measurements of pulsed currents may not be accurately determined, even if you take 50% off for 'measurement' mistakes, this stuff is real!
A simple way to determine how much excess energy is delivered is to ask him to connect a series of 100W light bulbs to the generator and see where it stops lighting up? At the generator output voltage, the total current can be easily measured. No complicated measurements needed. Agree?
cheers
chrisC
