New Wheel Design
Started by Alexioco, April 16, 2009, 07:52:51 PM
overtaker
Your very welcome. Good luck.
Alexioco
Ok, all of the levers are cut out, here are the exact final things I need to do to finish my wheel:
1. drill the holes for the levers to pivot on
2. attach the weights to the levers
3. fix the weighted levers into the wheel
then I'm complete and I will post, should be ready for either tonight (england) or tomoz...
Edit: Ok the holes have been drilled so number (1.) has been done
I should have it finished by tomoz, all that needs doing now is 2. and 3.
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
4Tesla
Good luck!!  I can't wait to see your wheel.
Tesla
Alexioco
Quick Update: The wheel should be finished tomoz, I got so involved in getting ready for I forgot today is sunday so the shops are shut (rightly so) I need long thin nails to hold the weights and thats it, I can then complete it...
In the mean while I want ask you all about somthing to do with the axle...
The axle has been drilled, but its not quite centre, its just slightly off, does this mean I wont get a fare result? my prevoius wheel which I posted here awhile a go didnt work, yet the tests coming up to it said it would just about work, again the axle was not quite right with that wheel, if it had been, would my wheel of worked?, this is what bugs me, unfortunatly my first wheel broke but I have saved one section of the movment and drew the mechanism as it was made and even coloured it in just incase I care to build it again some time, but a smaller version...
Also, just to let you know, this second (new) wheel of mine, its been made very well this time, its just I didnt get the axle quite right, I did use a compass very carefully, the axle isnt out by much at all, but it still bothers me...
Alex
AB Hammer
Greetings Alex
Ralph told me a carpenter's secret for center hole and more even cut wheel. First off take your wood and draw an exact cross for your four corners. Then drill the center hole at the x. Then I use a router and a guide to cut out the circle/wheel base.
I hope this helps, it has saved me some headaches. LOL
Alan
